Help!!!!
Old Apr 8, 2004 | 09:55 PM
otrovago's Avatar
Help!!!!
I took my 8 to get my system intalled and after 8 hours they cannot get the center console to work, the lights come on and the ac works but that's it, the info panel is dead and the radio is dead. Has any one experienced this when messing with the radio? They added a FM Modulator and an amp plus speakers and a sub, Please help!!! I have a 1 hour drive to work each way and with no radio is gona be a long drive, all that I can listen to is the cool sound of my engine...
HELP!!!!!
Old Apr 8, 2004 | 10:53 PM
Texas 8's Avatar
Integrity First...
If they can't fix it you'll have to take it to the dealer and whoever installed your system should be liable for the bill.
Old Apr 9, 2004 | 01:20 AM
Thinthi's Avatar
careful, i would take everything out and just go to the dealer. the service guy might just say cause you added stuff in you've voided yoru warrenty, i know mine would (he's a real @$$). best of luck to you, keep us updated, and don't void anything.
Old Apr 9, 2004 | 03:32 AM
Nubo's Avatar
Lubricious
Re: Help!!!!
HELP!!!!!
Check fuses.
Old Apr 9, 2004 | 07:08 AM
otrovago's Avatar
oh. no this is a big store in miami, its no mom and pop shop but still it sucks.... They will pay to fix it but, they told me to they will check everything again, he checked the fuses and they were ok. but if they can't figure it out I told them they will need to take everything out and put it back how it was....
Old Apr 9, 2004 | 07:56 AM
RX8by's Avatar
I had the same problem when I installed my M3 player. There was no lights in the large display. I found the small wire on the top left was connected but not fully insterted. I had to take every thing part and reconnect. If you are not using the original radio head unit the display will not work it is connected to it. Like I said it is the smallest of the connectors plugged into the top of the head unit.
Old Apr 9, 2004 | 10:03 AM
Flawless's Avatar
What shop was this in miami? Just wondering. I know my shop did just fine... they could probably fix it for you and charge a little bit. Then it will save you trouble of going to dealer. Where in Miami was this?
Old Apr 9, 2004 | 10:10 AM
phillip's Avatar
I had the same problem. Take the factory radio out and check all the wire harnesses.
Old Apr 9, 2004 | 01:02 PM
jtimbck2's Avatar
If the shop who installed his system is at fault, why would you advocate "sticking" it to the Mazda dealer by trying to claim it as a warranty repair? Isn't anyone honest anymore?
Old Apr 9, 2004 | 09:34 PM
otrovago's Avatar
its all good now!!1
ok they finally figure it out, apparently and I quote "there is something like a motherboard in the back of the radio and connections were not all the way in" I picked it up today and it has some kicking *** sound, I was so relief, they were going to pay for the repairs if need it, but you know that's just a hasle and I have a hard time getting time off work, I achtually took a day off to take care of the Tints and Sound system... it took a lillte longer than that but it was all worth it. I will post some picks tomorrow to see what you guys think...
The store was brandsmart, the intaller was real good and did a clean job, little problem but it was his first RX-8.
The only thing I didn't like was the fm modulator for my ipod it doesn't sound like I expected, but its ok...
Old Apr 10, 2004 | 03:29 AM
Tamas's Avatar
Registered Lunatic
Re: its all good now!!1
They never sound good. There's not much you can do about that...
Old Apr 10, 2004 | 07:55 AM
WHealy's Avatar
Mr. Blue Man
Sorry I missed the orginal question as I espereinced the same thing the last time I took my head unit out. I removed the piano black cover from the head unit to put my new heating/cooling system switches in. When I put it all back together, same results you described. I too it all apart and noticed that there are some connectors in the center of the piaon black plate that have to seed correctly in the head unit. I had managed to secure all the screws and not get this connected. I heard it snap the second time and all went well. If they had to removed your piano black face plate, I woudl bet these are the "computer connections" they were talking about.
Glad you got it fixed.
