glove box removal
Old Apr 5, 2004 | 10:01 PM
blueMT6's Avatar
glove box removal
Seen pictures of the glove box removed but need details. I note one screw in right hand corner but nothing else. There must be more to it than that. Trying to get access to that corner of the firewall. May need to drop the fan housing as well.
Old Apr 5, 2004 | 10:07 PM
Agent of Chaos's Avatar
Actually, I didn't need to remove any screws to remove the glove box..
With the glove box opened, I pushed in on the sides on the box and pulled it out further . Then on the bottom there is a lever holding the right side onto a plastic peg. I popped that lever off the peg, and then pulled the glove box out.
I may need to pull mine out again tomarrow to troubleshoot the FM modulator I recently installed, so I'll snap a couple pictures to further explain my ramblings above.
Old Apr 6, 2004 | 09:09 AM
cgrx's Avatar
DRIVEN
It is very easy. I think there is a cabin airfilter install on here that shows it.
Old Apr 6, 2004 | 05:02 PM
blueMT6's Avatar
Many thanks, just got the glove box out without damage using your directions. Will post my progress of passing an amp wire through firewall without drilling. Plan to mount amp on plywood in trunk using the web belt on the plywood that is already there for the tire kit.
Old Sep 3, 2005 | 02:18 PM
Kel Rx8's Avatar
if your not 1st your last
thanks buddy that was very helpful
I almost went nuts,but it took about 2sec
Danield97
Sep 30, 2015 05:59 PM
Racingjunkie
Sep 29, 2015 05:05 PM
Learners_Permit
Sep 27, 2015 07:38 PM
