Interesting eccentric shaft differences between old and new
Old Apr 5, 2004 | 06:00 PM
rotarygod's Avatar
Post Interesting eccentric shaft differences between old and new
I have seen someone here claim that some early Renesis engines actually used older 13B rotors and eccentric shafts. I find this highly unlikely. It was also claimed that the eccentric shafts were interchangeable with the older engines. Yes they will physically interchange but there is one very serious issue that would need to be addressed. The front main bearing oil hole on the Renesis shaft is moved about .150" forward. This would result in a mismatch between the oil hole and the main bearing oil groove if the 13B shaft were used. Using the original 13B shaft may have resulted in insufficient oil to this bearing. This info comes from the guys at Rotary Aviation. Just remember this is you ever want a custom built engine. Use ONLY Renesis parts and not 13B parts. There may something serious that can be overlooked! The Renesis e-shaft is physically stronger and lighter than the older shafts anyways.
Old Apr 5, 2004 | 06:30 PM
MazdaManiac's Avatar
Might that be why there were engine failures in some of the very early cars (like Canzoomer)?
Old Apr 5, 2004 | 07:02 PM
rotarygod's Avatar
Actually that is a very good explanation.
Old Apr 5, 2004 | 07:17 PM
Even if they only used the 13B-REW rotors (with the MSP e-shaft) the engine balance might be way off.
Old Apr 5, 2004 | 08:00 PM
rotarygod's Avatar
As long as you have the correct counterweights for the rotors you are using, the eccentric shaft weight is irrelevant.
If you get the wrong counterweights, it shakes impressively. No way anyone would drive a car like that.
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
PortedRotorTuner
NE RX-8 Forum
Sep 7, 2015 01:06 AM
