Squeaky Breaks
Old Apr 5, 2004 | 05:37 PM
KFence27's Avatar
Squeaky Breaks
Anyone experience squeaky brakes so far? I have 4800 miles and it recently became warm here. I had my windows down and heard the squeaking sound. Thought it was someones elses car at first, but unfortunately it was mine. With only 4800 on it, I don't expect the break pads to be worn out quite yet...
Old Apr 5, 2004 | 05:42 PM
rotarymagic's Avatar
Re: Squeaky Breaks
4800 seems kind of soon. But, one must keep in mind that these are high performance brakes. High performance brakes have a significantly shorter life span than 'regular' brakes. It is also very dependent on how hard you brake on average and how much wear, you particualr, put on your brakes.
With that said, 4800 seems way too soon, you should have them checked out by Mazda. Do you race our auto cross your car?
Old Apr 5, 2004 | 05:43 PM
Re: Re: Squeaky Breaks
Also, squeeking can be caused by dirt or brake dust as well, so try washing them extremely well with a high powered car wash hose.
Old Apr 5, 2004 | 05:49 PM
zoom44's Avatar
a quick search for Brakes and Squeal turned up these threads. happy reading-
search results by thread
Old Apr 5, 2004 | 06:08 PM
RenesisPower's Avatar
I have 6,500 miles on mine and they started to squeek at 5K miles. I have washed them throughly with high pressure stream of water and it has not helped.
Anyone has any other suggestions ?
Old Apr 5, 2004 | 06:18 PM
MazdaManiac's Avatar
As I have suggested in several of the threads referenced in the above noted threads, turn off your DSC, find an open stretch of road, get up to 60 MPH or so and then stand on the brakes.
If you do that a couple of times, it will end your problem. Its kinda fun, too.
Dirt, dust, rust and uneven wear cause the pads to squeal. Stomping on them will re-bed the pads.
These are high performance brakes and they are seldom driven hard enough to get up to operating temperature so they load up with dust and junk.
Old Apr 5, 2004 | 06:35 PM
Genom's Avatar
Not so Super right now
Yeah, what he said. I got a chance to do this over the weekend at the track and the squeel I had developed 3000 miles ago is gone.
Teach me to pay attention next time.
Old Apr 5, 2004 | 06:46 PM
RX8Lover's Avatar
I can't wait to try this on my way to work tomorrow.
Old Apr 5, 2004 | 07:16 PM
cas2themoe's Avatar
PoloRican Rotary
I'll need to try that too, me car does the same thing and I only hvae 4500 on it!
Old Apr 5, 2004 | 07:20 PM
Spin9k's Avatar
Momentum Keeps Me Going
ditto
Old Apr 5, 2004 | 07:22 PM
KFence27's Avatar
Yes this sounds like a very fun fix, remember to wear you seat belts...And i'll try not to do it in front of the speeding 18 wheelers on the NJ Turnpike.
Old Apr 5, 2004 | 08:02 PM
zoom44's Avatar
weird thing is i must stand on mine alot because i have never experience any brake squeal. yet.
Old Apr 5, 2004 | 09:38 PM
Velocity-8's Avatar
Whuumpha!!
Heh heh, I'm with you on this one!!
Old Apr 21, 2004 | 09:36 AM
huhsler's Avatar
Ack! I did the standing on my brakes trick (you should do it enough so that you're leaving rubber on the highway, right?) and the squeal went away for a few days.
Now, I've got it back. I don't want to have to do this all the time. Are there any longer term solutions, short of buying Ti or Ceramic pads?
Thanks.
Old Apr 21, 2004 | 10:45 AM
tpryor's Avatar
I have 11,500 miles on mine, and had brake squeal for about ONE day (at around 9000 miles).
There was a day where the car was driven through some deep water (one of Houston's "showers"), and they began to squeal the next day.
A trip to the auto parts store for some brake shim lube, 30 minutes putting new lube on the brake pad shims (3 on each side in the front, 2 on each side in the back), and not another sound.
I recently changed the brake pads all around (Mazda pads), applied the (included) lube to the new shims, still not a sound.
This could (should?) be done under warranty, one would think, if you didn't feel like doing it yourself.
Old Apr 21, 2004 | 11:04 AM
huhsler's Avatar
I'm taking my '8 in next Wednesday and I'll report back on whether they took care of this or not.
Thanks for the suggestion!
Old Apr 21, 2004 | 11:57 AM
Kain's Avatar
Human Being
"I can't wait to try this on my way to work tomorrow.
LOFL!!!!!!!
Old Apr 21, 2004 | 02:04 PM
B-Nez's Avatar
My squeaky breaks all the time. It's really annoying. I must be squeezing too hard or something. I have to buy a new squeaky at least once a week, but on the positive side - my dog loves the hand-me-downs. :D
Old Apr 21, 2004 | 03:44 PM
jdl's Avatar
jdl
just jd.
This is what I'm putting my money on.
That, and I wonder if folks with squeaky brakes also happen to use any commercially available wheel cleaner. Why? I recently used some of this stuff, and bingo! after 7500 miles of silence, suddenly my brakes squeal and scream. I'd bet good money I've inadvertently washed away the shim lube with the spray-on/hose-off wheel cleaner.
I'll reassemble the pads w/lube this weekend
Old Jun 6, 2004 | 05:51 PM
cash_money's Avatar
me too
I am also having the squeaky brakes problem. I've taken it in twice now to have it looked at, and both times they say, "The brakes look brand new, and we couldn't hear anything wrong."
I rode around with a tech, and we didn't hear anything. Of course, the next day- SQUEEEEEEAK!!
I'm getting pretty frustrated, and will be taking it back a third time.
I'm curious if anyone has repeatedly taken their car in and had the dealer find a solution.
Nothing worse then pulling up to a light, looking good, and then SQUEEEEEEEEEEEEEEEEEEEEEAK.
Thanks.
Old Jun 6, 2004 | 08:35 PM
legokcen's Avatar
The Turkish Delight
Just like on door hinges, you should spray liberal amounts of WD-40 all over the brake disc. That take care of the squealing.
:p :D :D
Old Jun 7, 2004 | 09:56 AM
Raevik's Avatar
An off-topic comment, I'm actually very pleased with the brakes in the 8 and how well they hold up. I've had many cars develop warping in the rotors even at a young age.
I HATE that feeling of "wobbling" when steadily braking b/c of the uneven rotor surface. Drives me nuts.
Old Jun 7, 2004 | 07:33 PM
47samurai's Avatar
Talking
Legokcen, That only takes care of BRAKE squealing. You still have the passenger squealing as you slide thru the intersections:D
R3Dream
Mar 7, 2019 09:11 AM
R3Dream
48
Mar 12, 2016 01:44 PM
snowrydr01
Nov 23, 2015 09:40 AM
erikcamacho15
Sep 12, 2015 11:23 AM
