New Speakers installed
Old Mar 26, 2004 | 03:06 PM
Gyro's Avatar
Rotary Abuser
My infinity's are in. The change in sound is notably better. Nice clean, bright highs without any distortion.
I went with the eyeball socket mount and flushed it in the panel.
Crossovers are in stock(Bose) location and a acrylic adapter was made to adapt the 6 1/2 round speaker.
I won't be redundant and show many installation pics, as my job was almost identical to that of Tamas.
Thanks Tamas, KKManiac and Whealey for previous pictures of door panel removal and installation ideas.
Old Mar 26, 2004 | 03:07 PM
Gyro's Avatar
Rotary Abuser
Door panel removed.
Old Mar 26, 2004 | 03:08 PM
Gyro's Avatar
Rotary Abuser
Interior
Old Mar 26, 2004 | 03:35 PM
Speed Racer's Avatar
Certified track junky!!!
Looks good. I'll have to check it out in person the next time we get everyone together.
My tweeters are still sitting on the shelf waiting to be installed. One of these days I'll get around to it. :p
Old Mar 26, 2004 | 04:38 PM
demmis's Avatar
why dont you put dynamat inside the doors???
i am sure the sound will be more nice
Old Mar 26, 2004 | 04:46 PM
mikeb's Avatar
100% Italian
wow
such a nice and clean set up--- congrats
Old Mar 26, 2004 | 08:52 PM
Omicron's Avatar
Very nice. Could you give us a bit more details about what speakers you bought, specifically, and how much you dropped on them and the cross overs? Thanks...
Old Mar 26, 2004 | 09:45 PM
Gyro's Avatar
Rotary Abuser
They are Infinity Kappas. They are a 6 1/2" component set. I think they were around $220. Crossovers were included. The aluminum tweeter domes are a perfect match for the interior as well.
I am running them from the head unit. I also have a set of Infinity Kappa 6x9's for the rear and an Infinity Basslink sub to finish it off.
Old Mar 26, 2004 | 11:25 PM
Omicron's Avatar
Nice! So how much did the rear set and basslink setup run? I'm seriously considering something similar... been looking at Focal and Boston Acoustics so far.
Old Mar 27, 2004 | 02:57 AM
Tian's Avatar
looks very nice..should sound nice too!!!
how do they sound better comparing to the stock ones?
Old Mar 27, 2004 | 08:43 AM
spdspappy's Avatar
I'm thinking about doing the same setup! I've been looking on ebay for those, but am undecided if I should go that route... The prices are a lot less than you'll find anywhere else, but they won't come w/ the Infinity warranty.
Old Mar 27, 2004 | 10:46 AM
Tamas's Avatar
Registered Lunatic
How is the Basslink working out for you? I'm also considering getting one of those (since it seems rotarygod won't finish his passthrough-box sub anytime soon )
Do you have some pics about the Basslink? How did you fasten it to the floor? Just started drilling holes or are there any special precautions needed?
Thanks.
Old Mar 27, 2004 | 05:14 PM
Gyro's Avatar
Rotary Abuser
Thanks.
I only have the front components installed so far. I do have the Basslink and rear 6x9's, but now I'm just waiting for a free afternoon to put them in. Like I said before....the new tweeters really brighten up the sound. Its a huge improvement as it stands now.....i cant wait to hear it after 3 way Kappas in the rear and a basslink.
I will post pics of the rest when it is done. My current dilema is where to tap power from. I would really like to avoid going to the battery if possible. There is plenty of power on the passenger side of the firewall.......its just knowing where to get it. Also, the basslink isn't terribly power hungry. If I was using 2 huge amps....I would go to the battery....but for a basslink?
The closest power is the outlet in the storage bin between the seats. It would be soooo easy to get it there. But I have to see what gage wire the socket uses. My guess is that it uses a small gage because it is not intended for a cigarette lighter. Then there is power in the fuse block near your left foot...I'm sure I can steal 20 amps out of that.
Old Mar 28, 2004 | 11:09 AM
bureau13's Avatar
I'm assuming you're using the non-Bose setup and so the head unit is your only amplification? Do you have any trouble getting it loud enough without distortion?
jds
Old Mar 28, 2004 | 11:21 AM
Gyro's Avatar
Rotary Abuser
jds
Yes. Non Bose car. With the Kappas being powered from the head unit, it is surprisingly loud and clear. The stock speakers were absolutely useless. Very flat. My taste is a very bright sound. I'm always cranking the treble up on any stereo I ever had. The Kappas have a very highs. I just need the Basslink to fill out the bottom end.
Old Mar 28, 2004 | 11:43 AM
Tamas's Avatar
Registered Lunatic
That's my experience too. I have different (Focal) speakers but the result is pretty much the same like Gyro said.
I think the key is to use good quality speakers that are highly efficient too - then you should have no trouble with the volume.
Of course I'm sure adding an amp would make the sound even better - and I'll probably do that once I'm done with adding the sub and my Neo MP3 player.
Old Mar 28, 2004 | 01:56 PM
bureau13's Avatar
I'm sort of leery of adding an amp due to the lack of real preamp signals....but I'm watching the threads on that topic too, because ultimately, that's probably the way to go.
I wasn't sure how efficient the stock speakers are...sounds like they're not as efficient as either the Focals or Infinitys so that's good to know.
jds
Old Jan 8, 2006 | 01:14 AM
BomberNYC's Avatar
just making old pictures appear.....
JimmyBlack
273
Feb 10, 2020 10:23 PM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
FubarI33t
Sep 28, 2015 08:45 PM
Rote8
Sep 22, 2015 03:43 PM
Randolph Alvarez
Sep 14, 2015 04:25 AM
