Fresh Shine and Fog Light Rewire
Old Mar 22, 2004 | 04:00 PM
epitrochoid's Avatar
Riot Controller
Enjoy it, I do :D
Old Mar 22, 2004 | 04:13 PM
nice pics..
Old Mar 22, 2004 | 04:25 PM
MarthaStewart's Avatar
Since your rx8 is also grey, as soon as I saw it I wondered to myself, if he's going to put a dinosaur on it.
Well, are you going to pop on a few decals of the dinosaurs?
Old Mar 22, 2004 | 04:30 PM
RX8Lover's Avatar
Re: .
that is friggin hysterical!!!!!!!! :D :D :D
Old Mar 22, 2004 | 04:33 PM
Riot Controller
lol
if you had told me this two days ago, I would have told you to check into the mad house. luckily i ran across that thread.
yes, my velicoraptor decals are on the boat from Japan right now.
Old Mar 22, 2004 | 04:54 PM
mikeb's Avatar
100% Italian
why are your HID's green
did you change them??
Old Mar 22, 2004 | 05:50 PM
Riot Controller
no, i had my buddy get in the car and turn them on and i intentionally snapped the pic right away to get the warming effect of the HID's
Old Mar 22, 2004 | 05:59 PM
BIU's Avatar
BIU
his 8 is from MARS! its aliveeeee :D
Old Mar 22, 2004 | 07:55 PM
Pinhy's Avatar
Back in Black
any info on the rewired fogs? i hate that you cant run the fogs without the headlights.....needs to be fixed....
Old Mar 22, 2004 | 08:06 PM
Positron's Avatar
Pinhy - Search in the DIY section for DRL (Daytime Running Lights). Omicron (among others) put up EXCELLENT directions on how to "fix" this.
mm
Riot Controller
there's a thread but I'll sum it up for you...
1. open engine bay fuse box.
2. remove the rear (in reference to the engine bay) fuse block by unclipping the 4 snaps.
3. locate the FOG relay, and the brown wire coming out of the bottom.
4.Locate the ACC relay, it's 2 slots to the rear of the FOG relay. you'll see
5. Cut the brown wire and leave a good amount of slack on the relay end of the wire.
6. Locate the small gauge white and red wire coming from the ACC relay.
7. use a wire tap or splice the brown wire into the red/white wire.
this trigger the fogs to come on with the ignition as long as the switch is on. there's a wire to only have them on with the corner markers, but this way they act as DRL's too.
vapor2
May 4, 2020 03:53 AM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
wayloco
Sep 1, 2015 09:03 PM
