Storage for the summer checklist
Old Mar 22, 2004 | 01:25 PM
Optitron's Avatar
I feel the need....
I need a checklist to go by for storing my RX-8 in a non-climate controlled storage unit for 6 months from April to September. Should I fill it up? Should I disconnect the battery? I know this is a general car question, but I'm not sure if there are special considerations for this car. I just bought it a few weeks ago and I want it to be the same when I get back.
Old Mar 22, 2004 | 02:02 PM
Sue Esponte's Avatar
Grand Poobah
This article might be helpful...
It's from a publication called Canadian Driver. It's about winter car storage. Some of the principles should be the same....sort of....except you're not driving a sports car in the months in which it was intended to be driven.
Hope you're planning a nice trip or have more interesting transport planned for those months! :D
-Eric
Old Mar 22, 2004 | 02:06 PM
Optitron's Avatar
I feel the need....
I'll be riding a bicycle in Japan for those 6 months. I'll be on a military deployment.
Old Mar 22, 2004 | 02:10 PM
Haze's Avatar
You'll need to put fuel stabilizer in the tank for that length of time and run the stabilizer into the injection system. Don't just dump it in the tank. You need to run the car to get it into the injection system, and make sure that the tank is full before you store it or condensation will dump water in your tank. Change the oil before you store, and pump the tires up to a higher level to keep the tires from flatting. Disconnect the battery and lock it up. However, if you disconnect the battery, there are a few things that you will need to know that are in the owner's manual about resetting some of the electronics. That's all I can think of off the top of my head. Have a good one.
Old Apr 1, 2004 | 01:21 PM
moRotorMotor's Avatar
Rotary eXperimental-8
I don't think I added any fuel stabilizer when I put in storage back in november . When I go and take the car out in the next couple of weeks, will I have any problem? Am I doomed? The tank was full and I disconnected the battery when I had put it in.
Old Apr 1, 2004 | 01:44 PM
Haze's Avatar
No, you're not hammered. It's just a good idea to keep the injectors from getting clogged with Shellac as the more volatile elements of gasoline evaporate out of the fuel system. The car will probably start fine, although it might run a little off for the first tank since the fuel may have evaporated down a bit. Once you run clean gas through it, all will be well.
Old Apr 1, 2004 | 03:17 PM
Thanks for the reply, Haze. I was having sleepless nights thinking about this. I know what I'll be doing the next time I put it away for the winter.
mdl0209
May 23, 2019 05:46 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
djgiron
Series II Wheels, Tires, Brakes & Suspension
18
Oct 15, 2015 04:07 PM
fireishot34
Sep 5, 2015 06:45 PM
