West RX-8 Forum Serving CA, NV, AZ, HI
SF bay area help available
Old Mar 19, 2004 | 05:17 PM
PUR NRG's Avatar
Continuing a tradition started with BMW friends, I am offering help to any DIYers in the bay area who would like to learn how to upgrade and maintain various parts of their RX-8 themselves.
Things I have experience with:
brake components--upgrade brakes, change brake fluid, etc.
mazdaspeed body part installs
xpel clear bra application
Things I will have experience with shortly:
sway bar installs
shock/spring installs
This is a "pay it forward" concept where I help you learn how to do things and hopefully you help and teach others in turn. So keep this in mind and ping me if you ever want help modifying your car.
________
Ipad Accessories
Old Mar 19, 2004 | 06:10 PM
murix's Avatar
We used to do this in Atlanta. I do not have a place to work on a car, but if anyone just needs an extra hand I am more than happy to help.
I have a lot of mechanical experience, BUT most of it as of late has been with piston motors. Of course, with a good shop manual there is not much that can not be figured out.
Check out http://www.armond30.com for some of the stuff the group of guys I hung out in Atlanta with work on.
Old Mar 19, 2004 | 07:49 PM
Xyntax's Avatar
THREAD KILLER
Great concept! Thanks PUR NRG. I'll keep this in my mind.
Old Mar 20, 2004 | 12:26 AM
brothervoodoo's Avatar
RainMan is Back
Good to hear from ya PUR NRG and awesome to know I have someone to ask pertinent questions if needed down the road. Thanks.
Old Jun 24, 2004 | 06:31 PM
psionic1's Avatar
PUR NRG, where are you located? I want to install new springs but don't really have the tools or driveway to do it in? Never done it before, but confident that I could with a little help...
I am in the north bay.
Old Jun 24, 2004 | 07:07 PM
Equis's Avatar
Speeding Ticket Magnet
Freakin Sweet I wanted to buy some of the Xpel Clear Bra but I didn't becuase I have no idea how the heck to do it! I'll keep this in mind.
Old Jun 25, 2004 | 09:30 AM
PUR NRG's Avatar
I live in Hayward. Swankmonkey has a great tutorial on spring/shock replacement. Besides ordinary hand tools you also need to rent a spring compressor.
________
BRUNETTE VIDEOS
Old Jun 25, 2004 | 10:01 PM
murix's Avatar
You can get the spring compressor from Kragen at the rate of $6/day.
Old Jun 26, 2004 | 02:52 AM
rx8spiritR's Avatar
----Got Rice?----
I need help on the Brakes. I have 2 front brake caliper off my 93 Rx7, they are 4 piston, i'm not sure in side, but are there any chance that i can swap them on my 8? they look soooo much better than the stock one on 8. if needed, i can get some FD rotors to fit the caliper , any one wanna help?
Old Jun 29, 2004 | 01:29 AM
rx8spiritR's Avatar
----Got Rice?----
i guess no one willing to help here......
Old Jun 29, 2004 | 01:55 AM
murix's Avatar
Do you really believe you will see an improvent in going to the RX7 brakes or is it for asthetic reasons? The RX8 has larger brakes stock and seems to do quite well with a single piston caliper. If you plan on changing out the brakes it would make more sense to go with something larger.
Old Jun 29, 2004 | 04:35 AM
rx8spiritR's Avatar
----Got Rice?----
dude, it also seems that the smaller brake can stop a 255 twin turbo, and us with only single pistion will have those sqeek sound with less than 1500 mile on the car....i don't know about larger brake, but i'm pretty sure that the 4 piston FD brake can do a lot better than the stock 8 brake. i'll give it a try this weekend since i'm upgrading shocks and springs.
Old Jun 29, 2004 | 09:39 AM
PUR NRG's Avatar
Do you know the RX-7 caliper mount is a direct fit on the RX-8? Ditto with the RX-7's brake rotor fitting on the RX-8's wheel hub? I have my doubts. Regardless, check out StopTech's site for articles on balanced brake systems. Even if you assume the calipers/rotors will fit what you're proposing will make overall braking worse, not better.
By my book anything done to improve looks that results in less performance is rice.
________
FORD FALCON PICTURE
Old Jun 29, 2004 | 03:04 PM
murix's Avatar
Have you tried new brake pads?
Old Jul 1, 2004 | 02:41 AM
rx8spiritR's Avatar
----Got Rice?----
no, but maybe i'll try
Old Jul 1, 2004 | 02:43 AM
rx8spiritR's Avatar
----Got Rice?----
i don't do it just for look, that's why i called it a UPGRADE
Old Jul 1, 2004 | 01:43 PM
PUR NRG's Avatar
rx8spiritR, did you read the technical stuff about balanced brake systems like I suggested? If the answer is yes then please explain why you still consider putting the RX-7 calipers on an upgrade. If the answer is no then please read the articles.
________
Lovely Wendie99
Old Jul 4, 2004 | 05:06 AM
rx8spiritR's Avatar
----Got Rice?----
i've will still give it a shot and see the difference, if i notice any problem i'll pose it up. so just let me be the little white mice.
Old Jul 4, 2004 | 08:00 AM
Roar 629's Avatar
i dont really recommand doin a swap from a FD caliper to an 8. the very first thing you need to worry about it's the power to weight ratio, FD weight rougly about 2850, the 8 is rougly about 3100 lb, also fd rotor 11.6 compare to the 8 is too small for an 18 inch rx8 wheel, it will look terrible with such combination, seem like you care about look more than performance from your previous post.
tbiggybig
35
Jul 14, 2022 06:14 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
Patricia Odell
SE RX-8 Forum
12
Nov 14, 2016 02:40 AM
archon
Oct 1, 2015 06:08 AM
urbanvoodoo
Sep 30, 2015 12:41 AM
