Single Din Install Trouble
Old May 12, 2012 | 09:38 PM
05_RX8's Avatar
Spent about 4 hours today trying to install a single din in my 05 RX8 with no luck. Color matched the wires, did everything I normally do and am only getting sound out of the subs the previous owner installed. It has the non-Bose system in it. This is the cd player and the harness I'm trying to install. Any help would be amazing.
Amazon Amazon
Amazon Amazon
Old May 13, 2012 | 03:46 PM
firebirdude's Avatar
User and Abuser
All your answers and more are in the FAQ at the top of the forum.
The short and skinny.... you're using the wrong harness. You need the
Metra 99-7510HG Metra 99-7510HG
Old May 15, 2012 | 06:03 AM
05_RX8's Avatar
The short and skinny.... you're using the wrong harness. You need the Metra 99-7510HG.
Ok so I got that in today, and still nothing works except for the subs.
Old May 15, 2012 | 07:53 AM
User and Abuser
You sure it's the non-Bose system? Open the trunk and look up at the rear speakers. Over closer to the passenger side, you'll see the Bose amp.
Just saying it sounds like maybe you didn't connect the remote turn-on lead for the factory amp.
If that doesn't fix your problem, not much else I can help you with without actually being there and looking things over in person. Unless you live in central FL, I'd just recommend taking it to a professional.
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
