Got Bass ?
Old Mar 16, 2004 | 01:25 PM
mlino01's Avatar
Got Bass ?
Just installed this last night and JL Rocks. My Wife said the whole house was shaking. I have the bass control mounted up front. The ability to adjust Bass to different types of tunes is awesome. The olny downside of JL is cost, pricey for sure. I'm going to have to fine tune the amp I got it pretty close but want it perfect. Anyone have tips on tuning an amp?
Old Mar 16, 2004 | 01:32 PM
adrian-1's Avatar
Ex- member.
I've got bass.
Yeah, JL rocks. Which amp do you have? Below is a picture of my box strapped down and the remote base ****.
Old Mar 16, 2004 | 01:38 PM
mlino01's Avatar
The Amp.
It's a JL 500 Mono Block. Nice Sub system and install Adrian. Any Tips on tuning appreciated. Mark.
Old Mar 16, 2004 | 01:40 PM
Omicron's Avatar
Very nice! How much did you sink into this? And, did you do the install yourself, or have someone do it for ya?
Old Mar 16, 2004 | 01:48 PM
adrian-1's Avatar
Ex- member.
I've also got the 500/1. I used the recommended amp settings found on this page...http://www.jlaudio.com/amps/pdfs/SYS_5.pdf and I only messed with the gain, it sounds great.
I see you used the remote turn on wire. I tried the signal sensing turn on but it was crap. (it wouldn't turn on or turned on with car off!, couldn't get the sensitivity on it right so I also used the remote turn on wire.)
Old Mar 16, 2004 | 02:15 PM
mikeb's Avatar
100% Italian
I got 2 12inch w-3 JL subs
adrian are those w7 subs? they must hit hard!! and you bass **** in the cup holder is clean as hell
Old Mar 16, 2004 | 02:35 PM
adrian-1's Avatar
Ex- member.
2 10" JL w6v2's. Purchased with the enclosure (prowedge model http://www.jlaudio.com/enclosures/CVS210RGW6v2.html). One of the few boxes that could fit perfectly. I didn't want to go the custom box route.
Old Mar 16, 2004 | 09:03 PM
mlino01's Avatar
Installed it myself and the sub and amp were 1100 with a amp hookup kit JL speaker wire.
Old Mar 16, 2004 | 09:05 PM
mlino01's Avatar
Adrian where did you get that box your amp is in? thats tight I also had problems when using the auto turn on with this setup I think it has something to do with the head units output section.
Old Mar 16, 2004 | 09:12 PM
mlino01's Avatar
Italian
This is also 100 percent Italian
Old Mar 17, 2004 | 12:26 PM
adrian-1's Avatar
Ex- member.
It's a Mazda accessory. Get it thru your dealer or order it from Rosenthal mazda for cheap, like I did. I also got the cargo tray from them. Very fast shipping.
cargo organizer
cargo tray
The organizer is made of hard plastic and is made to fit perfectly into the cargo tray. Drilled holes for the wires to pass thru and ran all the wiring underneath the tray. I was about to build a wooden box and plexiglass until I discovered they sold these.
Here's a couple more pictures. All pictures can be found here.
Old Mar 17, 2004 | 12:32 PM
guy321's Avatar
Humpin legs and takin nam
I had bass in my car, but they started flopping around and made slime all over the trunk so i had to toss them out.
Old Mar 17, 2004 | 12:50 PM
Omicron's Avatar
Bet they were kinda smelly too.
Old Mar 17, 2004 | 12:54 PM
guy321's Avatar
Yeah, they wouldnt boom either!
Seriously though, I have 2 kicker solo 10" in a sealed box. with a 1200watt amp. It's a cheap amp tho, I'm thinking of getting a JL, but they are so expensive for the powere I need to drive the kickers in that enclosure.
Old Mar 25, 2004 | 04:20 PM
RunnedAround's Avatar
Ya, I plan to make myself a box. Hopefully 2 12" kicker L7's will fit in the back of the trunk, I want the subs to face away from me, and I'm planning on making the box vented on the back, this way i can pull down the center part in the back seat, and feel the boom
Old Mar 25, 2004 | 10:21 PM
mlino01's Avatar
Adrian are you tapping the rear deck speakers ? and if so are you using line level converters or going staight into the amp. I was wondering if a high quality line level converter would be a cleaner signal or if the JL setup on this amp is as good as it gets. Mark
Old Mar 25, 2004 | 10:52 PM
adrian-1's Avatar
Ex- member.
Tapped into the rear speakers and I'm not using line level converters. Don't know if using converter would improve the sound.
Old Jan 7, 2005 | 08:03 PM
LiL BenNy's Avatar
Bubblicious? DEF.
where did you buy the subs/box set up i was looking on the site and searching on google but no luck yet...
Old Feb 2, 2005 | 11:56 AM
burnoutking999's Avatar
thats right...the KING!
IS THAT AN OUT OF THE BOX SYSTEM AND BOXES OR WERE THEY CUSTOM. They seem to fit nicely
sorry i didnt read far enough
Old Feb 2, 2005 | 05:07 PM
xrider's Avatar
Here's my bass setup. Little too much amp, but that's all I had, I figure if and when I blow the 10W6V2, I'll slap a W7 in there. Enough air space for it. Bass **** to the right of DSC button
Attached Thumbnails Got Bass ?-dsc01059.jpg   Got Bass ?-dsc01061.jpg   Got Bass ?-dsc01062.jpg
Old Feb 2, 2005 | 06:49 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
can you tell me how you installed that bass control ****. I want to out mine in that same place.
juicemantwon
Sep 26, 2015 12:30 PM
Rote8
Sep 22, 2015 03:43 PM
rilot
Series I Do It Yourself Forum
28
Jan 26, 2012 09:58 AM
fredraction
May 1, 2004 09:49 PM
JeRKy 8 Owner
19
Nov 29, 2003 07:22 AM
