245-40-19 Will these rub.
Old Mar 16, 2004 | 11:12 AM
RolenImportsRX8's Avatar
I would love to have a 40 instead of the 35 if possible. Am I just dreaming?
Old Mar 16, 2004 | 11:34 AM
Omicron's Avatar
No idea on the 19s, but I can tell you the 245/40-18s fit just fine. 1010Tires has a very slick and useful tire size calculator here that you might want to play around with.
You also might want to search around a bit here in the Wheel and Tire forum... seems I recall several members here with 19" rims are running 235s.
Hope this helps.
Old Mar 16, 2004 | 12:48 PM
Koala Joe's Avatar
Pink Slip?
If you go with 40 series tires, the overall diameter of the Rim + Tire would be slightly larger than stock, I think about 7-8mm larger. I don't know how this "increase" in size would affect the dynamics of the car's handling, but it's not going to affect your speed or acceleration, at least not noticable to the feel anyway. Omicron is right, the tire would fit just fine.
Old Mar 16, 2004 | 03:39 PM
Koala Joe's Avatar
Pink Slip?
Oops, I take that back, 245/40/18 is slightly smaller than stock 225/45/18, by about 5mm, according to those tire size calculator. I remember the guy who sold me my Volks told me that generally its better to go slightly larger, correct me if I'm wrong, or he's wrong. I'm running 245/40/18 in the back and 225/45/18 in the front. I'm planning to move up the back to 255/40/18 once the back tires worn out.
Old Mar 16, 2004 | 04:30 PM
PUR NRG's Avatar
Careful when you say smaller. 5mm huh? Is that width or diameter? If diameter, is that actual diameter or circumference? Remember what happened to the mars polar orbiter.
Better is also a relative term. Larger circumference means you travel farther per wheel revolution. That effectively reduces your torque and lowers your reported speed and odo readings. If you rack up lots of commute miles that results in less reported mileage on your car than actual, which helps resale value. However if you autocross then larger circumference reduces your acceleration which hurts performance.
________
BlushDelice
Old Apr 16, 2004 | 11:00 PM
Pinhy's Avatar
Back in Black
according to that tire size calculator, it is 3/4" diameter bigger diameter and 2" circumference....not to bad of a difference....id go for it.
Old Apr 25, 2004 | 08:18 PM
wayneside's Avatar
i'd go 245/30/19 good luck!
8yourv8
Jan 28, 2013 10:05 AM
Rotary__Rocket
Dec 5, 2012 09:39 PM
Rotary__Rocket
Oct 12, 2012 06:15 PM
coll
Dec 28, 2011 04:33 AM
tiltmode43
RX-8 Multimedia/Photo Gallery
29
Sep 19, 2011 10:18 AM
