questions about 2004 to 2011 engine switch..
Old May 2, 2012 | 03:16 PM
xxrx8xx04's Avatar
hey guys, i have a question:
i have a 2004 rx8,i want to switch the engine for a 2011 rx8 engine.
would the 2011 engine fit just fine ?
Old May 2, 2012 | 03:18 PM
EricB's Avatar
#225 of 1000
why
Old May 2, 2012 | 03:20 PM
RIWWP's Avatar
Plenty of reasons EricB.
xxrx8xx04:
It will physically fit. However, there are quite a few changes, including the ECU, the oil injection lines, the oil metering pump, etc... that will add quite a bit of work and lots of money on top. Be prepared to spend $5k+ on top of the price of the engine.
Old May 2, 2012 | 03:23 PM
xxrx8xx04's Avatar
well i want to change it because im having engine and transmission problems,and im just wondering if the transmission and engine would fit fine
Old May 2, 2012 | 03:24 PM
RIWWP's Avatar
Other than the wiring changing a bit on the transmission, the transmission is a direct swap. The engine most certainly isn't, due to everything else you need to update.
Old May 2, 2012 | 03:26 PM
xxrx8xx04's Avatar
alright,thanks man
Old May 2, 2012 | 03:32 PM
EricB's Avatar
#225 of 1000
Well if he wanted to do it for an updated engine, its kind of pricey.
Since his engine is going out, its not too bad but its still cheaper to rebuild/use another s1 motor.
If i was swapping a different engine it would be a 13b, something that makes power.
RIWWP's Avatar
You already have a 13b
(i know, i know)
Old May 2, 2012 | 03:46 PM
New Yorker's Avatar
By the time you finished, I bet you'd find it's easier and cheaper to just sell your current 8 and buy a newer one.
Old May 2, 2012 | 03:50 PM
Search Newb. There is a sticky about this and one other thread before that started by me..............
vapor2
Nov 3, 2020 03:38 PM
Skyl3r
Dec 2, 2019 04:51 PM
Shnifty
23
Dec 18, 2015 12:49 PM
Mr.Durden
Aug 12, 2015 02:21 PM
Rx8Lovin
Jul 25, 2015 08:39 PM
