NW RX-8 Forum Serving WA, OR, ID, AK
Rough Idle Problem
Old Apr 26, 2012 | 02:53 PM
patrick_andraste's Avatar
Gotta Love Two Strokes
Rough Idle Problem
My car has an even rough idle.
it always had a bit of a rougher than normal idle because of the K&N intake. That was an uneven roughness though.
If this were a piston motor I would say a sparkplug is fouled, that kind of even rough idle.
I am not getting any codes from the ECU and no CEL.
What I have tried so far:
Replace Coils with new OEM coils.
Replace Sparkplugs
Replace sparkplug wires
Clean Crank Position sensor.
reset crank position sensor (Brake pedal 20 times)
Oil level is good.
Once the engine RPM gets above 1200 or so, it smooths out. There does not seem to be a performance drop.
Fuel Mileage has gone up, from 17mpg around town to 19mpg and from 19mpg on the highway to almost 22mpg
I have 162,000 miles on the car.
the engine was changed out under warranty at approx. 32,000 miles
My theory is one of the apex seals is going bad, so there is blow-by at low engine speed causing low compression on one of the rotor faces at idle. when the engine speed is up, the blow-by is not enough to drop the compression and it would run fine under this theory.
How do I test for compression on a Rotary motor?
What else should I check?
If it is an apex seal, how long before it completely fails?
Old Apr 26, 2012 | 04:26 PM
TANKERG's Avatar
Mr. Örange
Any dealer will perform a compression test for you, or if you know someone with a compression tester for a rotary engine then you can do it yourself.
I had a rough idlewhen I first bought my car
Old Apr 26, 2012 | 04:30 PM
TANKERG's Avatar
Mr. Örange
Because I wasn't driving it hard. If you're not regularly getting the RPMs up you can foul your plugs. If you're trying to get good gas milage, that might be your problem.
Old Apr 26, 2012 | 05:45 PM
ShinkaEvo's Avatar
Triangular Bee Hive
Rough ideal as in rpm jumping up and down or shaky body?
Rough idle is mostly (not always) caused by intake component, check your MAF or any vacuum leak yet?
If you have low compression, it'll get low mpg and feel lost of power around certain rpm.
Old Apr 27, 2012 | 12:36 AM
Rough idle as in shaky body. it holds a pretty steady rpm, dipping every now and then if the fans or ac turn on which is normal. but the whole car shakes evenly at idle.
I pulled the MAF to see if it was dirty and it looked clean.
I will look for vacuum leaks.
Old Apr 27, 2012 | 01:00 AM
hornbm's Avatar
sounds like a motor mount, if I am understanding you correctly
Old Apr 27, 2012 | 01:13 AM
RawrX8's Avatar
Grocery Getter
It's only shakes 800-1,000 then above it smoothes out. Sea foam with me and see if problem solves Saturday.
Old Apr 28, 2012 | 10:15 AM
what time saturday? I am shooting girls in latex from 2pm to 6 or 7 pm
Old Apr 28, 2012 | 10:31 AM
MariesRX8's Avatar
Originally Posted by patrick_andraste
Rough idle as in shaky body. it holds a pretty steady rpm...
My 2004 has done that for years, even after new motor, coils, plugs, wires, air filter and cleaned MAF... and even new engine mounts.
It doesn't "stumble" or wander revs, I just feel the whole car vibrating a bit once it settles into it's lowest idle around 750-800 rpm. At 900 or above it's fine.
A lot of people seem to experience it, leading them to ask if there's a simple way to adjust the idle just a little higher... but apparently no easy way. Frustrating, as it just takes an extra 50-100 rpms to smooth it out.
Old Apr 28, 2012 | 10:35 AM
I think it is a vacuum leak somewhere, my latest wild *** guess...
It seems to be running lean throughout the RPM range.
either that or a marginal O2 sensor
Old Apr 28, 2012 | 10:36 AM
MariesRX8's Avatar
FWIW, my O2 sensor was replaced too
Old Apr 28, 2012 | 05:59 PM
kompressorlogic's Avatar
my 04 idles fairly rough too, especially with ac or lights on
Old Apr 28, 2012 | 06:33 PM
ShinkaEvo's Avatar
Triangular Bee Hive
Motor mount period.
Old May 1, 2012 | 01:21 PM
MariesRX8's Avatar
Originally Posted by ShinkaEvo
Motor mount period.
Well, to test the motor mounts, a Mazda TSB says:
Some vehicles may experience the following symptoms.
- On manual transmission vehicles, when decelerating in 3rd gear with engine speed less than 3,000 RPM at approximately 30 MPH (50km/h), then quickly depressing the accelerator pedal again, a hesitation may occur. This symptom can only be observed in this engine speed and vehicle speed range.
Has anyone tried this? Mine very noticably takes up "slack" when I do this before it starts accelerating again. Like a half-second of nothing, as if everything needs to twist a little before becoming tight again. I just assumed that was normal since I have nothing to compare it to.
Anyone try this and still get an instant response to pressing on the gas?
Old May 9, 2012 | 08:21 AM
rex8n's Avatar
I'm gonna try that in mine today mine is ideling rough as well it also has hard starts I put new plugs coils decarbed and cleaned thbe fuel sys it started ideling rough after a run at a meet.... hard starts came with the car xnt know what else to do about that
Old May 9, 2012 | 10:06 AM
TANKERG's Avatar
Mr. Örange
I think anyone reading this thread today will try this, I will
RevMeHarder
Jun 1, 2026 02:30 PM
gwailo
May 14, 2024 06:57 AM
DVerdeyen
Sep 13, 2015 11:19 AM
TJSiegrist
Sep 10, 2015 09:29 AM
DubbsLuvs8s
Sep 8, 2015 06:51 PM
