Sparco Seat & Seat Base
Old Apr 25, 2012 | 08:17 PM
Federighi's Avatar
Hi,
I looked through the seat thread here & also in the race forum but couldn't find any specific info on the subject.
Does anyone know of or have any direct experience using Sparco's seat & seat base combo & it's fitment in the rx-8? Also, were you able to retain the OEM seatbelt system? The seats will hopefully be going in my GT. Any info is greatly appreciated & please be descriptive as possible.
Thank you for looking!
Old Apr 25, 2012 | 09:59 PM
PM Hoss-05, he has Sparco seats and will have all of the info you seek
Old Apr 25, 2012 | 10:29 PM
EricB's Avatar
#225 of 1000
in most applications, its rare to find a base that fits perfect, many have to be modified.
Old Apr 26, 2012 | 01:52 AM
bse50's Avatar
#50
Bucket seat and 3 point seatbelt don't get along together.
Airbags and different bases are bad as well.
Io can get a bride or a nagisa seat rail to fit anyway.
Old Apr 27, 2012 | 04:08 PM
Federighi's Avatar
PM'd Hoss-05 a day or 2 ago but still haven't heard back. I wonder if he's still an active user?
Old Apr 27, 2012 | 04:55 PM
Sephitrask's Avatar
Zoom Frickin Zoom
The sparco base fits just fine. I did have to enlarge one of the holes slightly, but besides that all was good. I had a sprint series, and it worked ok with the belt, it took a couple tries before I got the routing right. Its a great investment for sure. Make sure you get a seat that fits you properly; I installed the sprint then had to take it out several months later cause I got fat
Old May 1, 2012 | 03:22 PM
hoss -05's Avatar
Lucky #33
Your PM was sent back. I do not believe the "Sparco"/Wedge brackets will work for you. Having a sun roof and being six feet tall I would would start looking other places for a lower bracket.
I am short, do not have a sun roof and only have about two inches of clearance from the roof. I like those brackets cuz they made them for both sides of the cars but there are other alternatives.
Old May 1, 2012 | 03:45 PM
Sephitrask's Avatar
Zoom Frickin Zoom
didn't think about the sun roof, that may be an issue. I got my car without one because there is no chance in hell I could fit in it with a helmet on if I had one. Though from my experience with the sparco brackets, I don't know how much lower they can be made. It already sits directly on the brace that runs across the floor of the car. The only way I can think to have more room is to run without sliders, but getting in and out of the car would be a MAJOR pita (I am 6 feet tall and had to slide the seat back every time I wanted to get out)
Old May 2, 2012 | 08:13 AM
yale02's Avatar
Still plays with cars
I could not get it to work in my car. I have the pro2000 seat mounted directly to the floor. This seemed to work best for my application with is a fully caged race car with only one driver. Most prefabricated seat mounts seem to place the seat and driver way too high in the car. I also tried a different base made by Planted - same issue.
Stock belts will likely not work in a fixed seat but might in a two piece.
Old Jul 18, 2012 | 11:07 AM
yale02's Avatar
I recently had all of my interior out to better facilitate the painting of my cage. For the purposes of someone searching for seat mounting options and wanting a visual aide, I attached some pictures of my mounting solution that involved a bit of fabrication. The car is a race car and not street driven. The seat bracket "slides" by unbolting it; I am the only driver.
Attached Thumbnails Sparco Seat & Seat Base-dscf1574.jpg   Sparco Seat & Seat Base-dscf1575.jpg
Old Jul 18, 2012 | 11:19 AM
AZ R3's Avatar
iZoom
Check out my thread:
https://www.rx8club.com/series-ii-in...sports-233954/
Planted tech seat bracket. Direct bolt in (pics in thread). Use with ANY aftermarket rail or side mounts. No fabrication or modification needed.
Dave - just saw your post - what trouble did you have with the Planted bracket?
Old Jul 18, 2012 | 11:28 AM
yale02's Avatar
It fit well and my brackets worked; however, I was seated too high to wear a helmet. I'm 5'10".
alming1132
Sep 30, 2015 11:30 AM
DeltaJ802
Sep 29, 2015 01:20 PM
Stubbs
Sep 27, 2015 04:06 PM
