Help with RX8
Old Apr 23, 2012 | 08:45 PM
FlynRX's Avatar
Help with RX8
hi all i have a auto 2005 rx8 done 90300 km. im having the misfiring issues. its one where the revs drop below 1000 rpm and close to 500 rpm all of a sudden its misfiring this is mostly when im stopped at the lights or when the car is parked but the engine running mostly when it is hat after driving for a while ...
the issues is that i have had all the common problems look at
so far i have had these replaced
Spark Plugs
Coil Pack
HT leads
Manifold solenoid
Cat removed and a hi flow one put in
Compression test was done and it came out fine also
engine mounts was replaced(due to the vibrations)
secondary injectors replaced
Full service done on it also (oil, filter, air filter etc)
above all this im not getting check lights for the misfiring, got told by the workshop that its not the ssv not sure if they checked it or not but generally will have the CEL light on.
also checked the MAF sensor it looks normal no dirt or anything.
Pleases help running out of ideas and money mostly lol
Old Apr 24, 2012 | 04:05 AM
ASH8's Avatar
Super Moderator
Gee you have just about done what I would have suggested..
Have you checked and cleaned the Throttle Body?
I would also makes sure you have no vacuum lines missing, unplugged or crossed.
Have you reset ECU?, disconnect Negative Battery Terminal, stomp on brake pedal about 20 times, reconnect cable. Start Car, Do the Power Steering reset by turning steering wheel all the way to the left and then all the way right.
Old Apr 24, 2012 | 05:12 AM
bse50's Avatar
#50
Ash you got the 2 procedures mixed up... disconnect battery terminal\keep the brake pedal down to "discharge" the system quickly or...
Key on ON position, 20 quick brake pedal stomps, see the oil gauge sweep up and down.
Old Apr 25, 2012 | 04:46 PM
FlynRX's Avatar
mechanics reset the ecu after the injectors got done ...
but will look in to the throttle body cleaning nd the vacuum lines
thanx
Old May 2, 2012 | 08:22 AM
gvnz's Avatar
Guys. I'm getting the CEL light (yellow light) since yesterday, but no noticeable change in driving or performance. Only issue is it hasn't been serviced for about 10k kms or about 12-13 months, though I have been adding oil, coolant etc. where do you guys get your cars serviced and how much does it usually cost. Thanks.
Old May 6, 2012 | 11:45 AM
stinksause's Avatar
The Stink w.o The Sause
Pull the code, there are about 150 different reasons why you may have a check engine light ... from a loose gas cap to a Dirty MAF and everything in between
Symptoms do sound like it is an SSV. Are you running a catch can?
SSV cleaning: http://rezelse.blogspot.com/2011/10/...-resolved.html
Old May 6, 2012 | 11:52 AM
wcs's Avatar
wcs
no agenda
http://vimeo.com/7093611
dirty dirty maf
spank
Old May 11, 2012 | 12:25 AM
FlynRX's Avatar
lol ok my biggest problem is i dnt wana touch the 13b engine .. but last weekend i made up my mind lol whats the worst that could happen ither replace a motor. hmm well il jus have to save up and rebuild it ...
but any how the main issue was the miss firing so i cleaned the maf with the maf sensor cleaner and man did this make a diffrnce. it RAN smooth when i men ran i man she goes fine no dropping of the revs in d now it is running at 750 rpm constant ..... BUT lol BUT now there is a slight miss in p and n .... also now i have the vibration . where im at a light an bam if stopped for a while itl be vibrating .so new issues
Missfire in P and N
Vibrating at lights
oh and i also cleand the sensor thats located under the pulley like sprayed it with beta maf cleaner .
Old May 11, 2012 | 12:34 AM
FlynRX's Avatar
k i just realiseed i forgt to do the ecu reset would this have to do any thing...
Old May 11, 2012 | 12:35 AM
FlynRX's Avatar
Sorry NO catch cans yer
Old May 11, 2012 | 09:06 AM
stinksause's Avatar
get one and reset your fuel trims
05TR1CH
Apr 18, 2023 04:56 AM
Skyl3r
Dec 2, 2019 04:51 PM
SupraG
Sep 21, 2015 12:09 AM
vetteor8
Jul 25, 2015 11:43 AM
RX7.9
Jul 20, 2015 12:01 PM
