Coolant light on startup
Old Apr 23, 2012 | 12:10 AM
mopiko's Avatar
Hi Guys,
Just this few days, the warning light (Coliseum in Rome lookalike) will come up whenever i start my car. After a few minutes of warming the car. It disappears.
Just changed my coolant bottle less than a year ago.
Please advise if that is anything to watch out for.
Just alittle worried on why the light comes ON and OFF.
What sort of coolant should i topup with? if my coolant level is alittle low.
Currently its the green FL22 from MAzda in it.
Old Apr 30, 2012 | 05:45 PM
Munchy's Avatar
RX n00b
Sensor is screwed up.
Common problem. Ignore light, just make sure to check coolant level when you do oil changes.
Old Apr 30, 2012 | 05:55 PM
Bullitt's Avatar
In the pipe five by five.
It will probably start staying on for longer periods of time and eventually stay on permanently. It's a pain.
Old Apr 30, 2012 | 07:22 PM
Socket7's Avatar
ಠ_ಠ
Bad sensor. Unplug the wire attached to the coolant bottle and the light will stop coming on.
FL22 should be mixed with more FL22. You don't mix water into it.
Azki23
Jun 27, 2018 03:48 PM
erikcamacho15
Sep 12, 2015 11:23 AM
Irvinb16
Sep 11, 2015 10:27 PM
