Custom Fiberglass Boxes
Old Apr 21, 2012 | 08:46 PM
Geradenoz's Avatar
ROTOROCKET
I have been working alot with custom fiberglass boxes now. I recently have been toying with my rocketship and decided to remove the bulky, nasty looking sub box in my trunk.
I then decided instead of doing my school work to mask off and make a mold in the corners of the trunk of my rx-8.
fresh box, un-cut un-altered, Some masking tape removal.
Through the next couple of days i will be uploading where i am at so far along with the boxes, I will be inserting a 12" ring angled t-wards the cab. Also porting the boxes, and mounting the amp somewhere breatheable (Possibly next to port) = ]
Any suggestions you guys have, criticisim or anything is welcome id love to improve in what ever area.
Most of the pictures of the mold i wasnt to concerned with removing all the masking tape and was just snapping pictures when ever i took a breather. These boxes are SOLID and was thinking about after the final product maybe selling a few sets. I will continue posting pictures maybe a video if i have time to keep everyone posted. I plan to possibly paint boxes red // black and have a holister on top for a book or 2.
Curing = ]
4/22/12 , kitty litter = ]
with some trash bag suction, actually had 1 shopvac, 1 household running at the same time so i could work with both front peices
Some end results of front Name:  IMAG0916.jpg
we ended early, partner in crime got a headache finished by cleaning up, re-inforcing insides with matting, sanding edges smooth then working the two peices together with some glass. Will post more pictures tmmrw , Thanks for the lol
Smoothside 320 grit, Other just primer
First shot of red
sanded with 600 then re shot red then 1000 then reshot red
Now I started introducing a black lacquer with a clear coat you can see the color difference, More matches car
one with the sub in
Size:  75.0 KB need new ones iknow!
inside trunk
Port regulator on the way via mail!
Turn out immaculate !
will put pictures of ports when complete, and also when its all wired up and the subs in it for good!
grill not mounted yet
Plugd ports
Old Apr 22, 2012 | 06:40 AM
firebirdude's Avatar
User and Abuser
So far so good.
Old May 7, 2012 | 05:26 PM
usiris208's Avatar
How much? Lol
Old May 7, 2012 | 06:47 PM
User and Abuser
Looks great.
What's with the circular cutout/gray grills in each corner of the box? Please don't tell me that's suppose to be a port....
Old May 8, 2012 | 04:31 PM
Geradenoz's Avatar
ROTOROCKET
@usiris, all in all ran me about 350+ in mats. Mostly just time.
@firebirdude, yea those are but there not working so well, alot of whistiling noise emmited from them, any other suggestions ? its a 2 1/2 inch hole!
Old May 8, 2012 | 04:47 PM
comebackqid's Avatar
make me some! how much I just want 1 12in sub.
Old May 8, 2012 | 05:21 PM
User and Abuser
You. Have. No idea. What you've done.
Simply drilling a hole in a sealed box does not a ported box make. A port or vent is a duct of air, usually, inside the box.
The length of the port will vary based on enclosure size, subwoofer performance and output desire. Lengthening the port will lower the tune of the box giving better low frequency extension and will generally flatten the response curve, at the cost of overall output. Shortening the port will basically do the opposite (give you a loud and peaky output). You basically have a super leaky sealed box.
The worst part about this is that there is ZERO chance you can add a port inside that box. Despite being a royal PITA now, the box is far too small. You essentially made some awesome looking fiberglass subwoofer boxes.... then chopped a hole in them. I suggest finding a similar looking cover, that will actually plug the hole.
And lastly, not sure where you bought your supplies from, but $350 is OUTRAGEOUS. I made a box for two 15"s with knytex bi-axil for less than that.
Old May 8, 2012 | 05:40 PM
paimon.soror's Avatar
i was gunna say, it looked like a drilled out hole and vents ...
not to mention that if you want to really go the route of putting flared or slotted ports in your enclosure, it is in your best interest to really smooth out the inside of the enclosure of sharp edges and hard bends.
Old May 11, 2012 | 05:30 PM
Geradenoz's Avatar
ROTOROCKET
Okey so we've sealed the vent with appoxy, with some clingwrap lining the inside so dosent splurge out the front we will appoxy the vent to box aswell for air tight lock.
Old May 14, 2012 | 05:24 AM
LiL BenNy's Avatar
Bubblicious? DEF.
cool, looks similar to the ones i made back in 05...
http://muibubbles-design.com/index.p.../rx-8-sub-box/
interesting method with the kitty liter, garbage bag, and vacuum... never seen that before! did you apply some sort of mold release? id imagine the bag being stuck to the FG and being a PITA to peel off....
nice job
Old May 14, 2012 | 07:51 AM
User and Abuser
nice job
Got any more pictures of the finished product after your fiberglassed the whole trunk?
Old May 14, 2012 | 02:46 PM
LiL BenNy's Avatar
Bubblicious? DEF.
no!!! =( i dont know if i ever took any =(
Old May 14, 2012 | 04:52 PM
Geradenoz's Avatar
ROTOROCKET
nice job
No actually just left the vacs running for about 15 mins (for the flash) then put in the sun for about 45 mins (cook a little more) and the bag TO MY BIGGEST surprise just peeled off, actually easier than the tape from the corner mold. Thanks !
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Danield97
Sep 30, 2015 05:59 PM
mitchrx8
Sep 13, 2015 08:05 AM
