Hopeful Simple Metro Fix
Old Apr 20, 2012 | 12:53 AM
04MazdaMan's Avatar
KY Metra Kit Install Help
So not to long ago i decided to give the aux hack a try that explained in the link below...
http://www.whatsmyip.org/ipodrx8/14.php
I did the soldering myself i had never soldered anything before so i was thinking this might possibly be the problem. I cross soldered a small amount but cleaned it up best i could. It looked pretty good. I put everything back together and everything fit together nicely but after plugging it back up I found that nothing was working besides the fan speed controls and the emergency lights button and only hot air would come out.
I figured i fucked up the radio so i decided to get a metra kit and a new stereo. I bought this one
http://www.autosoundcentral.com/Metr...p/957510hg.htm
Once again i put everything together and still giving the same results as before.
Im thinking it could be a bad fuse, or some hidden wire i accidentally disconnected doing all this. I hoping it's something that easy but hell i dont know what to look for. please help!
Old Apr 20, 2012 | 12:57 AM
04MazdaMan's Avatar
btw, its a 04 GT and It did have a 6-disk.
Old Apr 22, 2012 | 02:00 AM
04MazdaMan's Avatar
Bump. help me out and ill be eternally greatful.
Old Apr 22, 2012 | 06:29 AM
firebirdude's Avatar
User and Abuser
Donno man. Sounds like your HVAC control board may be cracked. It's happened to a few people on here, and they were able to repair it. Should be able to search for it. Might be in the FAQ.
Old Apr 24, 2012 | 10:25 AM
04MazdaMan's Avatar
no luck
I tried to do some research about the HVAC but came up, more or less, empty handed. Are you sure i still have a HVAC board since ive installed the metra? There's no circuit board connected to the HVAC anymore.
Old Apr 24, 2012 | 10:32 AM
User and Abuser
Back of the controls. If I remember right, the cracks were happening around one of the corners. I think the top right corner by the temp control. I'll search for you in a bit. Getting ready to hit the green.
golf... not weed.
Old Apr 24, 2012 | 02:06 PM
Munchy's Avatar
RX n00b
Had the same problem (only hot air coming from vents), fixed it yesterday.
You need to take the HVAC controls (your *****) out and separate them from the circuit board inside. You'll see 3 tabs (2 on top, 1 on bottom) of the fan speed and cold/hot ****. Open the case and you'll have access to the the circuit board.
On the back of the circuit board where the cold/hot **** was, you'll see 3 solder joints in a row. Re-solder these even if you don't see anything wrong. Mine had a crack only seen under a microscope, which was causing the problem.
I'm not sure if this will fix your A/C, mode, defrost, and vent buttons.
Old Apr 24, 2012 | 02:11 PM
Munchy's Avatar
RX n00b
Here's the DIY thread with pics:
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-no-heat-repair-heater-control-158200/
Even Metra themselves sent me these EXACT instructions and pictures when I called them.
You might want to go to a pro for the soldering if you're not sure what you're doing since that circuit board costs upwards to $350.
Old Apr 24, 2012 | 04:39 PM
User and Abuser
Thanks for the help Munchy. Just got back from golfing...not a good day.
Old Apr 25, 2012 | 02:19 PM
04MazdaMan's Avatar
Well Ill definitely give this a try later. Ive got a buddy who's really an electrician so maybe he's better suited for this job. Ill keep ya posted.
Old Apr 25, 2012 | 02:26 PM
04MazdaMan's Avatar
I noticed on the DIY link it saying to hold down the power button and wait for it to show something or another. However, mine shows nothing, ever, well since it broke. No time, Climate, or radio. Would a crack like youre speaking of cause this aswell?
Old Apr 25, 2012 | 02:33 PM
Munchy's Avatar
RX n00b
If you installed the Metra kit, you don't have a power button anymore lol
If your red screen up top doesn't work at all either, it's most likely the Metra box that's fucked. You might want to contact them or exchange the unit. Double check your wiring too.
Old May 4, 2012 | 02:20 PM
04MazdaMan's Avatar
You were right! Metra sent me a bad one. Got the new one in today and works fine. thanks for your help.
WranglerFan
Aug 21, 2022 01:29 PM
Brokegang
Jan 3, 2016 12:45 PM
