Auxiliary input cuts out after 30 seconds
Old Apr 17, 2012 | 03:39 PM
pacmantravis's Avatar
Hi everyone,
I'm having a problem with the AUX input on my RX8 and am hoping someone here can help out. I have the 6 disc Bose System and am using the PIE adapter (http://www.autosoundcentral.com/PIE_...alpalpmrca.htm)
I have had the system for around 8 months and it has worked well with the exception of this same problem happening for around 2 weeks 3-4 months ago. I am not sure what "fixed" the problem before, it just started working.
Here is the issue:
When I press the CD button to get into AUX mode the display shows "EX" and I can hear music through the system for around 30 seconds. Then everything goes silent. If I press the CD button again to get it to show "EX" music will continue to play for another 30 seconds before everything goes silent again. This has how I have been listening to external sources for the past week -- 30 seconds at a time.
I have tried multiple audio sources (iphone, galaxy s2, etc) and have the same problem with any device I connect to.
Like I mentioned earlier, I've had this issue before and it "magically" started working like normal. However, I would like to get to the bottom of this.
One difference I can tell is, when things are working as they should I do not see just the "EX" on the screen. I normally see "EX 1" . To me it seems like the head unit can't tell there is a signal going through or that anything is plugged so it shuts off the input after a predetermined amount of time.
Has anyone seen or experienced this issue before?
Old Apr 17, 2012 | 04:10 PM
firebirdude's Avatar
User and Abuser
Hmmm strange. My money is on a faulty PIE adapter. You could try poking around the PIE harness with a multimeter. See if the signal out of the PIE adapter drops out after 30 seconds, or the signal stays solid but the headunit stops outputting audio.
Old Apr 18, 2012 | 07:47 AM
Ok, I'll try that out this weekend. Thanks for the advice!
Old Apr 18, 2012 | 11:19 AM
ninjajim4's Avatar
+1. i've had to have mine replaced, had it less than 3 months at that time. it would intermittantly get extremely fuzzy or not work at all. since replacement, not a hitch
crimson809
Aug 14, 2016 10:03 PM
FubarI33t
Sep 28, 2015 08:45 PM
Jb4ker96
Sep 27, 2015 10:06 PM
Learners_Permit
Sep 27, 2015 07:38 PM
