Swapping Single Disc for Six Disc
Old Apr 16, 2012 | 06:42 PM
Bamsterman's Avatar
I need to replace my radio and I want to stick with OEM. My 8 came with the single disc. If I wanted to put in the 6 disc OEM cd changer, are there any mods that I'll need to do? I also plan on adding a sub and amp to it soon, if that makes any difference.
Old Apr 16, 2012 | 07:12 PM
LunchboxCritter's Avatar
Disco Biscuit
I would recommend not doing that as the 6 disk is a notorious POS.
I think that the single disk plays MP3's, and if so, then you should be able to fit more than 6 disks in MP3 on a single disk.
If you plan on doing a sub setup, I would highly suggest you go with an aftermarket head unit (alpine or pioneer would be my preference).
Old Apr 16, 2012 | 07:16 PM
firebirdude's Avatar
User and Abuser
Should swap right in and sub/amp will make no difference.
But unless you're getting the 6-disc for nearly free, I would encourage you to think again about sticking with OEM. The sound quality of even a cheap aftermarket headunit is head and shoulders above OEM. And you can use a flash drive or iPod to store FAR more than 6 CDs. And the aftermarket headunit would negate your need for a line output converter for the aftermarket amp, saving you ~25 bucks.
Your choice though.
Old Apr 17, 2012 | 06:18 AM
Bamsterman's Avatar
Well the reason why I was sticking with OEM is because I mainly need the A/C controls. I didn't find anyone on here that still had them. The cost for me to buy the A/C controls, metra kit, and new radio, would all cost me more than it would be for buying all of it together as OEM. It's reall the cost of the metra kit that sends the price over my limit
Old Apr 17, 2012 | 08:15 AM
User and Abuser
Ahhh I understand. What happened to your A/C controls?
cliffkemp
Dec 24, 2024 10:48 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Patricia Odell
SE RX-8 Forum
12
Nov 14, 2016 02:40 AM
bosstin87
Oct 5, 2015 06:52 AM
