Pic Request: Any 18x9.5+22 on stock height
Old Apr 5, 2012 | 11:30 PM
EricB's Avatar
#225 of 1000
Hello everyone, just curious if anyone has any pictures of this setup.
This is rx7 fitment if anyone is curious and will be transferred over this summer or the next, just wondering how this would fit.
I posted in the will it fit and J said it would be super retarded looking but a pic to confirm this might make me rest my case.
Also no, i dont plan on lowering my rx8 at the time. Its currently my DD and dont want to be pouring money into it (thats what the rx7 is for)
Thanks.
Old Apr 6, 2012 | 12:01 AM
Grace_Excel's Avatar
Charles Bundy
It's gonna look odd. But here's mine which is an ET +38...
Old Apr 6, 2012 | 12:14 AM
EricB's Avatar
#225 of 1000
^THANKS!! i love how you provided alot of pictures!
Im still new to figuring these wheel sizes in my head, you sit basically flush from what i can tell am i correct?
How much farther will i be past the fender with the +22? Also can this be remedied by a little neg camber?
Ill also be on 225's until i wear my set out and go wider for the 7.
Old Apr 6, 2012 | 12:22 AM
TopGear8's Avatar
mkuhnracing.com
Good luck getting that much negative camber without lowering the car...
You gain camber as you lower the car, you cant just add as much negative camber as you want...
Don't do it, it'll look stupid with such an aggressive wheel at stock height.
Spend $200 for a set of Eibachs or S Techs that will eliminate the unwanted wheel gap, and look worlds better...
Old Apr 6, 2012 | 12:29 AM
Charles Bundy
+22 is only half an inch wider than mine. The front wheels surely will stick out, however, the rears will clear at 225 tires. I wish I could find a picture of my car with almost 450 lbs (two adults) of load in the rear seats mimicking a drop of two inches on the set up I have. As far as suspension alignment and camber, I'm at a loss. You should inquired with tiltmode43 in this Aggressive Wheel Fitment thread.
Old Apr 6, 2012 | 12:38 AM
EricB's Avatar
#225 of 1000
^thanks, thats what ive been looking for.
as far as camber, i was under the impression that we could change it, albiet not by much, i was hoping it would suffice.
ive been looking into the gf210's for a while, with a lower springrate they will do less damage and ill be able to get more life out of my oem bilsteins. Im not looking forward to replacing them when they blowout because of the price. Though if i bring it to a shop it will be ~$500 for springs, install and alignment.
Old Apr 6, 2012 | 12:45 AM
Charles Bundy
Not the picture I'm looking for regarding the rear wheels tucking. But it's close, I was hitting bumps up the hill. I didn't feel the tires rub other than the suspension's bump-stops.
Old Apr 7, 2012 | 02:34 AM
monchie's Avatar
I HATE SPEEDBUMPS!
That house by the famous Hollywood sign is i think the most expensive house in Hollywood...lol
Old Apr 7, 2012 | 12:14 PM
tcole6's Avatar
Assuming your rims are 9.5" it would be a touch over 5/8" further out. Not that .129" is much, just sayin'
Old Apr 7, 2012 | 02:04 PM
EricB's Avatar
#225 of 1000
so you are saying that my rims will stick out 5/8" (~1.5cm) in the front?
Old Apr 7, 2012 | 11:33 PM
Charles Bundy
They will stick out, these are the only images I have saved and you can kind of imagine as my wheels align evenly with the fenders.
Old Apr 9, 2012 | 08:03 PM
EricB's Avatar
#225 of 1000
Can someone tell me how much they will stick out? 5/8" or 1/2"?
Old Apr 16, 2012 | 10:36 AM
brilliantblackrx8's Avatar
That all depends on your camber specs in the front, but with stock height the difference is going to appear negligable due to so much gap.
Old Apr 16, 2012 | 11:52 AM
tcole6's Avatar
16mm(38-22)/25.4mm(one inch)=.6299" or slightly more than 5/8" from what Grace_Excel was showing you.
Old Apr 16, 2012 | 12:36 PM
225 on a 9.5 is a big stretch, that may take away from some of it, but you may want to think about this before installing. Do a google search for RX8 18x9.5 +22 and take a look at some pics. Couldn't find any with +22 but some with +15 and +20 that look like stock height or close. Just think about it before you do it, that is all. RavSpec had something similar to this on his ads for the Work Emotion 11R a few months back. I think he was running 18x9.5 +15 with a 235 on stock height. You can get somewhat of a feel through these pics, although his are sticking out 3/8" more.
Old Apr 16, 2012 | 02:53 PM
J8635621's Avatar
Pew Pew Pew
Why is this even a question? Either answer is far too much. (9.5 +38 sticks past the fender at stock height anyways)
Old Apr 16, 2012 | 03:34 PM
Wind Dance's Avatar
Central Valley RX8
My new wheels are 18x9.5 +20. Even lowered on gf210+koni yellows it still sticks out a bit. At stock height it will poke like no others. I don't have any pics yet just saying...
Old Apr 18, 2012 | 10:06 PM
EricB's Avatar
#225 of 1000
because its not the end of the world if my wheel/tire sticks out 5/8". You have said that it will stick out 1" and others have said 1/2" and 5/8" but i think according to grace's specs his is just about flush so add another 5/8"
anyway, i just want to know basically if i should save my $ and buy the wheels after i buy the fd in the same specs(fd fitment) or buy them now to spruce up the rx8 a little bit for a little while.
1 inch however is too much for me and id rather just wait at that point. The stretched tire is aggressive enough, not to mention the shitty height.
for the record i was going to buy some sprint springs but the op decided to not answer my pm and answered someone elses so he sold them. that would have gained me 2 amazing sexy inches.
Old Apr 18, 2012 | 10:12 PM
J8635621's Avatar
Pew Pew Pew
your answer is pure lol. Thanks.
Old Apr 18, 2012 | 10:37 PM
Charles Bundy
I can't simulate how the front will look lowered with 245/40 tires in 18 x 9.5 +38 wheels. But here are pictures of the rear (under load with two adults).
Old Apr 26, 2012 | 01:48 PM
Charles Bundy
EricB, if you're still wondering.
More pics..
Still a little rubbing on the rears which a little more camber should help. The fronts are rubbing the fender liner which I might remove.
Old Apr 26, 2012 | 02:42 PM
I think EricB has gone a different direction at this point, EricB am I right?
Old Apr 27, 2012 | 12:47 AM
EricB's Avatar
#225 of 1000
-___- sprint springs! 2inch drop!!
this should be good for future reference. Thanks grace for the boatload of pics.
Old May 13, 2012 | 12:26 AM
mistahjg's Avatar
Thumbs up
this is what it would look like if you wanna go with the sortaflush mode,
18x10 +22 rear
18x9.5 + 22 front
front: 20mm wheel adapter
rear: 5mm spacer.
http://www.flickr.com/photos/77117762@N08/7185349866/http://www.flickr.com/photos/77117762@N08/7185349866/ by http://www.flickr.com/people/77117762@N08/, on Flickr
http://www.flickr.com/photos/77117762@N08/7180396990/http://www.flickr.com/photos/77117762@N08/7180396990/ by http://www.flickr.com/people/77117762@N08/, on Flickr
http://www.flickr.com/photos/77117762@N08/7180396674/http://www.flickr.com/photos/77117762@N08/7180396674/ by http://www.flickr.com/people/77117762@N08/, on Flickr
Old May 13, 2012 | 01:58 AM
EricB's Avatar
#225 of 1000
^looks good! Alot of useful pictures for people not wanting to lower their car.
i happened to find a set of the only springs that ever appealed to me and bought them. NOW im hellasunk.
stock wheels with a 2inch drop if anyone cares.
Rear
Front
im hoping some spacers remedies my problem.
thanks again for grace finding me a multitude of pictures and brilliantblack for finding me the springs.
anyone care to start taking bets when my shocks blow out?
