Sub and amp help
Old Apr 3, 2012 | 06:14 PM
fatkat4's Avatar
Sub and amp help
need some help my son bought an amp and some speakers for his car he got 2 of these speakers
also it is not a stock radio it is a clarion cz102 so none of the existing wiring in the car are used
http://www.alpine-usa.com/product/view/swr-1043d/
and an amp the brz1200
http://www.hifonics.com/Hifonics_Brutus_BRZ_Amps.html
and we wired them as option 1 for a 2 speaker setup as per this link
http://www.sonicelectronix.com/item_...SWR-1043D.html
the problem we are having is the amp is over heating he says its so hot you cant touch it we have 12 gauge speaker wire from amp to speakers
and 2 gauge power and ground wires
its mounted in the trunk the amp is screwed to the back of the speaker box
and help would be greatly appreciated on to solving this heat issue
Thank you
Old Apr 3, 2012 | 06:17 PM
RX8Soldier's Avatar
Time for boost...
^Have you read the FAQ sticky in this sub-forum? That could answer your questions...
Old Apr 3, 2012 | 06:36 PM
fatkat4's Avatar
i did not look before i posted but i did look now and i didnt see anything that would help
thank you
Old Apr 3, 2012 | 09:39 PM
firebirdude's Avatar
User and Abuser
Is the amp actually kicking into protection? Or is it just very hot to touch, but plays fine? I'll assume it's kicking into protection and not playing. Does it play fine if you keep the volume very low? How long does it take before it kicks into protection?
You are presenting the amp with a 4-ohm load, when it's stable down to 1-ohm. I'd try disconnecting the subwoofers all together and power on the amp. Does it still get scorching hot? If so, the amp is faulty. If not, try connecting only one of the subwoofers. Try it in series (8-ohms) first, then again in parallel (2-ohms).
nadodave
Aug 28, 2019 05:55 AM
Learners_Permit
Sep 27, 2015 07:38 PM
juicemantwon
Sep 26, 2015 12:30 PM
just1jack
Sep 9, 2015 04:45 PM
