Steering Breaks.
Old Apr 1, 2012 | 10:12 PM
Scotty Eckels's Avatar
Steering Breaks.
So my power steering light came on, I just got the rack and pinion changed out for a new one, does anyone have any idea what else it could be? or had this problem.... the electronic assist just is not functioning.
Please Help
thanks
Old Apr 1, 2012 | 10:19 PM
dozer's Avatar
on his 3rd rx8
have you tried cleaning out the connectors? shouldve tried doing that before replacing the rack and pinion, couldve saved you $$$$$$$$
Old Apr 1, 2012 | 10:22 PM
The rack really was messed up, ever time i would turn the wheel it would make a weird noise. but no i have not tried the connections, where are they located. what happened is i went to get gas, turned off the car(everything was fine) forgot my wallet, so i put the cap back on the gas and turned on the car, and bam no power steering........
Old Apr 1, 2012 | 10:27 PM
dozer's Avatar
on his 3rd rx8
yeah sounds like your connectors, theyre located right under the airbox, so youre gonna have to remove it to locate em. buy some Keyboard duster (canned air) and some dielectric grease, you unplug em, air it out, both male and female side and dab some grease on both sides, and plug back
the red part ^ sorry i used this pic to help out another forum member that was having the same problem plus something else
Old Apr 1, 2012 | 10:57 PM
thanks, i really appreciate it! is it a lot of work to get to? and if for some reason that doesn't work, what else could it be?
Old Apr 1, 2012 | 11:23 PM
dozer's Avatar
on his 3rd rx8
its an easy job, i did it myself without even really knowing the car. if its not that i have no idea what else it can be
Old Apr 2, 2012 | 12:48 AM
StealthTL's Avatar
Metatron
Title changed to reflect content -
'Help' is not a title.
Old Apr 2, 2012 | 06:08 AM
godesshunter's Avatar
Voids warranties
Did you recalibrate the steering by turning full lock left and right after the new rack was installed? Not sure but that may have to be done.
Old Apr 2, 2012 | 08:12 PM
Ok, so i think there may be a short on the wires, when i turn the car on sometimes the light comes on and no power steering and sometime it works perfectly.
Would it still be the connectors in this case? or what
Old Apr 2, 2012 | 08:27 PM
StealthTL's Avatar
Metatron
Classic connector symptom.
The system works until it senses a poor connection, then it cuts out to prevent a steering error. Taking the key out resets it until it sees the fault again.
S
Old Apr 2, 2012 | 08:37 PM
so if i clean the connector, will it work good again, or do i need a new connector thing?
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
Evan Gray
Sep 26, 2015 12:30 PM
Wurromurro
Sep 20, 2015 05:02 PM
