RX8 ABS/Traction control. Both stuck on
Old Apr 1, 2012 | 11:40 AM
dskuce's Avatar
Okay recently when i started driving my traction light comes on and so does my abs light. Also i kinda hear a noise from the front left when idling. any suggestions?
Old Apr 1, 2012 | 11:53 AM
alnielsen's Avatar
The ABS system with throw a error code in the ECU. Get your codes read. It should tell you where the problem is.
Old Apr 1, 2012 | 11:09 PM
GeorgeH's Avatar
^What he said, but realize that not all code readers will show chassis codes. If your code reader says NO CODES then go somewhere with a better reader.
Also, there is an excellent thread on this over in the Troubleshooting section. The short story is that many different things can cause these lights to come on. In my case, it was a faulty ABS unit, which is pricey. Hopefully for you it is only a blown fuse.
ladnarf1
Apr 29, 2021 11:53 PM
uZu
Dec 30, 2015 12:35 PM
foxyRoXy8
Aug 18, 2015 10:26 PM
reddozen
Series I Engine Tuning Forum
Aug 7, 2015 10:20 AM
RX7.9
Jul 20, 2015 12:01 PM
