Stereo help
Old Mar 29, 2012 | 01:02 PM
Scotty Eckels's Avatar
Stereo help
hey so i bought the metra install kit for my rx8 but it was the one for the double din one is there a way that i can buy a open square plastic holder to go on top or below the stereo?
any ideas?
Old Mar 29, 2012 | 01:08 PM
tronicj's Avatar
I get Paid $0.50 a Mile!
You could find something like this and just ditch most of it except the din sized box.... Might have to do some custom fitting not to let it fall out on you.
http://www.sonicelectronix.com/item_...9B-CR1289.html
Old Mar 29, 2012 | 01:19 PM
firebirdude's Avatar
User and Abuser
I'd think about returning the kit and buying the correct one. Or sell it yourself and buy the correct one. You don't want hack up an install in an RX8. This isn't some 89 Bonneville hoopty.
But if you insist, the universal pocket from Metra would probably work better. They have mounting holes right on the sides of the pocket. And I think that's how you'll have to attach it to the double-din brackets on the Metra kit. 99-00-8000 or 88-00-9008 are the part number if I remember right.
But again, I'd really try to return it or resell it and buy the correct one. Or buy a double din headunit. They're cheaper than you may think.
Old Mar 29, 2012 | 03:00 PM
yea i just bought a kenwood double din that was not too expensive.... do u know what the other things in the back are for? like the 2 yellow preouts and the other 2 cables coming out?
http://www.sonicelectronix.com/pictu...ture_id=773057
this is a link to the stereo...
Old Mar 29, 2012 | 03:30 PM
User and Abuser
The composite video connections are clearly labeled "R-CAM" for rear camera and "VIDEO" for video output. If you're not installing a rear camera or another monitor, then ignore them. The two wires not in the harness are clearly labeled "REVERSE" for reverse trans signal and "PRK SW" for parking brake switch. If you're not installing a rear camera, ignore the reverse wire. However, the parking brake switch wire must be connected properly for full motion video to display. You can google any bypasses or hacks for this, so you can watch video while the car is in motion. It may be as simple as grounding the wire, or installing a switch, maybe re-pinning the harness, etc. I don't know. Never done the bypass for that particular unit.
Old Mar 29, 2012 | 03:56 PM
so with that i will just be able to splice the kenwood parking break wire with the ground from the other wires?
Old Mar 29, 2012 | 04:00 PM
User and Abuser
I said you'll have to google it. Maybe that's all it takes. Maybe it requires something more. Every model from every manufacturer is different. Google video bypass DDX318 and see what you can find. You might have to lurk on some Kenwood forums or something.
crimson809
Aug 14, 2016 10:03 PM
Hdez Mex
Sep 24, 2015 02:47 AM
Wurromurro
Sep 20, 2015 05:02 PM
Randolph Alvarez
Sep 14, 2015 04:25 AM
