rx8 choke
Old Mar 26, 2012 | 04:26 PM
erotary13b's Avatar
rx8 choke
Hows it going im new to this forum and my question is, is that my rx8 just recently got a straight pipe on it (legal in fl) and now it shakes when on idle like it wants to turn off help me please
Old Mar 26, 2012 | 04:28 PM
erotary13b's Avatar
my cat converter was about to go so decided to do straight pipe
Old Mar 26, 2012 | 04:31 PM
What does the thread title have to do with your problem? How do you know your cat was about to go? Year, mileage, AT or MT, last time coils and plugs were replaced? Have you checked for the obvious (vacuum leaks, gerbil stuck in the intake. etc.) things?
Old Mar 26, 2012 | 04:41 PM
erotary13b's Avatar
2004, 105,000 miles, automatic, last time i tuned it up was around November no leaks what so ever and when i drive the car it chokes like if im at 4000 rpms it goes down to 2,000 rpms and at idle it shakes hear and there
Old Mar 26, 2012 | 04:46 PM
Tune up as in new coils, plugs, wires? Any check engine light?
Old Mar 26, 2012 | 04:50 PM
erotary13b's Avatar
yea the whole tune-up, yea i got a check engine light i diagnose the car and it says exhaust leak but im assuming thats for not having a cat converter (correct me if im wrong)
Old Mar 26, 2012 | 04:53 PM
erotary13b's Avatar
come to think about it my old mechanic was a shitty mechanic he used, recycle oil on my car so im assuming he messed up on my tune probably using cheap parts
StealthTL's Avatar
Metatron
The car doesn't say 'exhaust leak' it gives a code.
.....and what would that code be?
Old Mar 29, 2015 | 08:14 PM
beng11306's Avatar
TX Me Too!
Mine does the exact same thing...
I just bought an 04, 6port, 6spd, Manual last week and the engine chokes out around 4000 rpm as well.
I ran a diagnostic and it showed codes for IAT circuit high input(P0113) , MAF sensor High and low input signal(P0102-P0103) , and TP sensor 1 and 2 High input signal(P0123-P0223)
I thought all these problems were being triggered from the MAF sensor so I went to replace it.
When I looked in the plastic connector that is ribbed that connects the Air filter and the Throttle body there was some liquid pooled up in there. (I thought maybe this was Throttle body cleaner the kid I bought the car from had maybe used to try to fix the problem [subsequently ruining the MAF sensor] before i bought the car???)
I cleaned it out the liquid and replaced the MAF sensor but the problem comes back after I drive for about 20-30 minutes after startup.
Any thoughts???
I got the car for a really cheap Price so If problems persist I may just sell it to someone else to break even. Or send it off to the auto auction this week
05TR1CH
Apr 18, 2023 04:56 AM
Skyl3r
Dec 2, 2019 04:51 PM
SupraG
Sep 21, 2015 12:09 AM
vetteor8
Jul 25, 2015 11:43 AM
RX7.9
Jul 20, 2015 12:01 PM
