My Dyno!
Old Mar 13, 2004 | 02:06 PM
JERCS's Avatar
Awesome Member
Wink My Dyno!
The SLC Rotary club had a dyno day today so I gladly paid my 50 bucks and threw my 8 on it!
Found out something rather interesting, might have already been posted but I don't care.
I have an RE Intake and by the numbers (only compared to the average RX-8) the intake lost me a lot of mid-range torque.
I don't have a scanner here so I'll post it and scan it later.
Me (3/13/04):
Max Power: 169.4 @ 8200 RPM
Max Torque: 123.9 @ 4200 RPM
Base run (bone stone, 3/5/04):
Max: 167.1 @ 7300
Torque: 136.2 @ 5700
There was another 8 there maybe he'll post his results.
I will take off the RE intake and run a dyno with just the stock and then run it with the K&N drop.
oh btw this was just 3rd gear pulls.
-guy:D
Old Mar 13, 2004 | 02:09 PM
hmmm very interesting...
Old Mar 13, 2004 | 02:10 PM
JERCS's Avatar
Awesome Member
So the airflow is restricted, so it could be really good at either higher rpms... free way driving, or with an exhaust.
Old Mar 13, 2004 | 03:44 PM
smrx8's Avatar
WOW its depressing looking at the max power it gave,and you had a re intake . i was planning a dynoing mines but the shop dyno was having problems i see if i can get to them next week. ill go cry now
Old Mar 13, 2004 | 06:57 PM
blksf8's Avatar
I don't have a RE intake, but will be dynoing w/ Chuck @ RE next Thursday or Friday stock and w/ the RE intake. I'll post results when done.
William
Old Mar 13, 2004 | 10:17 PM
olias's Avatar
I was the other 8 at the dyno day. Car is all stock except for Redline MTL in the trans.
P: 168.2 @ 8000
T: 135.8 @ 5200
Mark
Old Mar 13, 2004 | 10:25 PM
bia619's Avatar
I'm curious. Did either of you who dyno'ed your cars do the "limp mode" trick? those numbers are quite low.
Old Mar 13, 2004 | 11:43 PM
Omicron's Avatar
I think they're at like 4400 ft altitude too, which makes considerable difference.
Old Mar 14, 2004 | 12:45 PM
klegg's Avatar
I see you
I think if I have to read one more "Dyno" thread I may just kill myself..the car SHUTS DOWN ON THE DYNO! please, use the search function and learn!
Old Mar 14, 2004 | 01:16 PM
rotarygod's Avatar
Both stock cars runs were very close. Close enough. The intake equipped car had much less midrange torque. I'd love to see the dyno plots overlaid. 2 peak horsepower gain with a sacrifice where the car is driven 99% of the time doesn't sound like a good investment to me. The stock airbox is tuned. Now the tuning is gone. The added airflow doesn't show an apreciable, feelable gain on the top end. I won't rule out the fact that the results are from limp mode though and indicitave of the true potential of the intake.
I too would like to know if you guys did the wheel sensor trick though to fool the car so it could be dynoed. The 4400 ft altitude still corelates well with those at sea level when you factor in air density differences.
Old Mar 14, 2004 | 02:40 PM
Rotary Extreme's Avatar
Jercs:
If you want to put your car on the dyno again. I have a series of tests for you to run. I will pay $100 toward your runs. Email me at rotaryextreme@aol.com so we can discusss this.
Chuck Huang
Old Mar 14, 2004 | 07:44 PM
olias's Avatar
These were fairly quick runs, so nothing was done except to turn off the DSC.
Salt Lake City's airport is at 4227 feet above sea level.
I can't post pics but I have the graph that compares the two runs. Basically, Jercs' 8 was at or below mine until right around 7200 RPM, the point where the last intake valve opens. From 4200 - 7000 was where the biggest differences were.
Mark
Old Mar 14, 2004 | 08:38 PM
murix's Avatar
What kind of dyno did you use?
Old Mar 14, 2004 | 08:44 PM
MazdaManiac's Avatar
Unfortunately, those numbers sound quite familiar....
Old Mar 14, 2004 | 09:59 PM
olias's Avatar
A Mustang dyno.
As far as these numbers go, just insert the typical "I love this car" comment here. Besides, on road experience has shown me this car runs about the same as others with similar rated power.
Old Mar 14, 2004 | 10:04 PM
Rotarian_SC's Avatar
Free Autographed Pictures
If you look at the CZ dynojet the whp of stock rx8 was around 169. Also i thought i remembered hearing that base mustangs and gt autos had bad gearing for their power.
Old Mar 15, 2004 | 11:28 AM
JERCS's Avatar
Awesome Member
Insert "I love this car" too :D
I'll talk with the tech at the garage about all the dyno things you guys have said.
-Guy
Old Mar 15, 2004 | 11:43 AM
Gord96BRG's Avatar
Still kind of a waste of money, don't you think? If you know that the ECU goes into a safe mode and restricts power on a dyno without doing the limp mode bypass (wheel sensor tricks) - why bother? It's not a real, valid number...
Regards,
Gordon
Old Mar 15, 2004 | 11:59 AM
zoom44's Avatar
well its a good base number to start your mods from.
Old Mar 15, 2004 | 12:06 PM
JERCS's Avatar
Awesome Member
Regards,
Gordon
If we always do it the same way it's a good base number to work with. And since all the 8's this garage were done the same way it (if nothing else) shows about the intake. Now maybe with the test Chuck will give from RE, it'll correct itself.
Old Mar 15, 2004 | 01:02 PM
Mike Ockstynee's Avatar
A mustang dyno reports #'s about 15 pct less than a dyno jet, FYI.
Old Mar 15, 2004 | 01:42 PM
JERCS's Avatar
Awesome Member
And the tech at the garage told us that the Mustang was more accurate and the dyno jet reported high numbers that weren't real.
Old Mar 15, 2004 | 02:22 PM
islandsoon's Avatar
I don't see how this can be. If in fact the car is in safe mode and the car is dumping fuel/retarding timing/doing whatever it can to be in safe mode, any changes made to the engine will just give you a comparison against the safe mode base. What does leaning out the mixture with a piggyback or changing the air intake and then testing it against a safe mode setup tell you?
Old Mar 15, 2004 | 02:27 PM
My point is 90 pct of the dyno's you will be comparing against are going to be dyno jets, so when comparing a dynosheet of a mustang dyno to a dyno jet factor in a rough 15 pct.
FYI, a dyna-pac will measure less than a mustang dyno or dyno-jet and they will tell you that a dyna-pac is the most accurate.
i say its all a crock of crap and the only way to judge and get an accurate real world estimate is take your car to the drag strip and get a before and after trap speed.
Old Mar 15, 2004 | 04:34 PM
JERCS's Avatar
Awesome Member
Agreed. But if we use the same one to compare mods it should be fine. I was posting merely to show my results I found with the RE intake. That based on these numbers, I was below average torque in the mid range. The numbers I could care less about, I didn't buy this car for the HP!
Chuck and mentioned doing more tests, so we'll see what he wants to do. Plan to use the same machine to give correct feedback. I think I need to dyno with the stock intake in and re-dyno with RE in.
