navigation has no power
Old Mar 5, 2012 | 06:48 AM
8ya's Avatar
8ya
Since I've cotton my rx8 7 months ago.. the navigation hasn't worked. this morning I did the room fuse procedure and nothing my car is an 04 the nav has no power, you can manually lift up the screen but the screen is blank and the open button does nothing.. you can hear the disk spinning and the light in the dvd input lights up..any help would be appreciated should I take it to car toys or mazda?
Old Mar 5, 2012 | 06:39 PM
8ya's Avatar
8ya
Forgot to add that I have a sub and amp in the trunk think they diconected it?
Old Mar 23, 2012 | 10:03 AM
8ya's Avatar
8ya
Any help would be appreciated.. thanks
Old Mar 23, 2012 | 10:26 AM
firebirdude's Avatar
User and Abuser
Sorry but I can't be of much help to you. A ton of things could be the problem. If you've checked all the fuses under the hood and all the fuses in the driver's kickpanel, then I'd just take it to Mazda. Car Toys likely isn't going to touch your stock navigation system. Sure you could try poking a multimeter around the navi-hood motor for power, etc. But you said the screen is blank too. Heck maybe the previous owner had a carputer installed in the navigation hood and tore it all out before he sold the car. Who knows.
If Mazda trys to charge you more than a couple hundred bucks, just leave it and go aftermarket. Aftermarket navi performs twice as good anyway.
In fact, Mazda is probably going to charge you an hour labor TO START with. Just to troubleshoot. That's usually ~$100 right there. I'd personally use this as an excuse to replace the headunit with a nice double-din navi. Then you'll have high quality navigation, bluetooth, on-screen iPod controls, DVD playback, etc etc etc. The stock navi is just not worth saving unless it's a simple blown fuse.
Old Mar 23, 2012 | 07:01 PM
8ya's Avatar
8ya
Thanks for the advice.
vapor2
Jul 9, 2016 07:35 AM
jer2911
Sep 29, 2015 06:37 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Evan Gray
Sep 26, 2015 12:30 PM
Trekk
12
Sep 25, 2015 03:08 PM
