Magnecor plug wires
Old Mar 12, 2004 | 04:42 PM
darkducati's Avatar
Magnecor plug wires
For anyone that may be interested, Magnecor now has a plug wire set available for the RX-8. The part number is 45435. I would guess that the price is around $50.00.
Old Mar 12, 2004 | 09:11 PM
BoxerGT2.5's Avatar
Know anywhere you can get them???
Old Mar 13, 2004 | 11:56 AM
RX-8 friend's Avatar
They are nice wires, and work well on my 3rd gen. You have to "burp" the plug boots when you press them on the plugs. Take a paper clip and bend it straight with only one loop left. Insert straight part into plug boot (same end as plug goes into), put plug boot on plug. Trapped air will leak by the clip wire, then you pull it out. It's a bit awkward but I do it all the time. Otherwise, the trapped air will not let you push the boot all the way onto the plug. Not good, as the connection may be left open and arcing. That will destroy the wires. I also use silicone clear dielectric grease around the plug insulator/boot interface. This makes it much easier to get off later.
If you look at the plug wires, you may notice they do not touch or pass through any parts. I doubt fancy wires will help, other than look cool.
Old Mar 13, 2004 | 12:15 PM
and thats all i want them for..
Old Mar 13, 2004 | 02:51 PM
BoxerGT2.5's Avatar
Well I know Magnecor makes 8.5mm and 10mm wires. Not sure about which/or both will be available. Is there advantage of having one size over the other and vice versa?
Old Mar 15, 2004 | 09:42 AM
darkducati's Avatar
They actually make the RX-8 wires in 7, 8, and 8.5mm. The part number posted is for the 8.5mm.
Old Mar 15, 2004 | 02:20 PM
dcfc3s's Avatar
RX-7 Guru
Magnecor makes some EXCELLENT plug wires. Best part is they last damn near forever - put them on, don't worry about it again .
You likely won't see any power gains with them - the stock wires (if they're anything like the stock NGK wires on the RX-7) are actually pretty damn good.
Magnecors are just incredibly well built, rugged, and do the job. The only difference going to another size is more outer insulation on the wire - that's it. I have the 10mm in my 10th Anniversary because it was only like $5 more and looks cooler .
Dale
RevMeHarder
Jun 1, 2026 02:30 PM
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
WranglerFan
May 31, 2022 07:51 AM
DVerdeyen
Sep 13, 2015 11:19 AM
iwannarun
Sep 6, 2015 01:37 PM
