My tranny is cooked
Old Mar 12, 2004 | 11:22 AM
WTF no turbo's Avatar
My tranny is cooked
Car is at the dealer with a cooked tranny.The part that gets me is how bad the tech knocks the transmision in this car.He actually said the tranny in the 8 is weaker then the miata.I will know more on monday.
Old Mar 12, 2004 | 11:45 AM
Omicron's Avatar
Not true. While it is made by the same company, it's a different, stronger unit. You tech is full of it.
But good luck with it, and keep us posted!
Old Mar 16, 2004 | 04:28 PM
Broke_Apex_Seal's Avatar
I guess what his tech is saying is "It is not strong enough to take the power" of the 8. But it is just a guess.
Old Mar 18, 2004 | 10:27 AM
j9fd3s's Avatar
it is the miata tranny (6 speed) and in a heavier car too boot.
mike
Old Mar 18, 2004 | 11:49 AM
Well new tranny is on the way.I was told that they were going to replace bearing then it became the entire tranny.I will let you guys know.They tech did say that the flywheel replacement will help the tranny as well as performance
Old Mar 19, 2004 | 06:38 AM
PhineasFellOff's Avatar
I'm sorry, I'm a little confused here.
Why would replacing thte flywheel help anything? Did you buy an aftermarket flywheel for them to put in along with the new tranny?
Old Mar 19, 2004 | 08:37 AM
SHOWOFF's Avatar
NOT SEARCHING
I broke mine too, I was coming to a stop rollling about 5 mph and I put the car in 1st gear, I heard a loud pop and the car would no longer go into 2nd gear, I never was told by the dealer what happened to the transmission but they ended up replacing it. Only took like 4 days though they were pretty fast about it. While it was there they also replaced the rear diff b/c it was whining really loud at 45 mph.
They need to beef up the driveline on this car. I don't drag race the car or do any crazy launches from 6 grand or anything so I can't figure out why this happened.
Old Mar 22, 2004 | 04:56 PM
93silverFD's Avatar
I have the FM2 kit on my miata. Pushing just over 300 to the rear wheels (yes, on a dyno). The car has been daily driven since 95 having the turbo for the last 3 years, 125k on the odo. I have never had any problem with the tranny. I doubt a week tranny is the problem. Its more likely to be a bearing problem that led to a catastrophic failure than a design weakness. Although, Mazda does have a history of underengineering.
theblinkof
Oct 4, 2023 05:24 PM
JAYDOH
Sep 24, 2015 01:54 PM
Juan Montenegro
Sep 10, 2015 06:28 PM
