Sub-Woofers Cutting Out...Bose System
Old Feb 23, 2012 | 09:50 PM
Rewire's Avatar
Unhappy Sub-Woofers Cutting Out...Bose System
So I've had this problem for about a month now...never got around to posting anything about it... Just looking to get a quick answer since search turned up nothing.
The Situation: Subs cut out after a small amount of time depending on the volume level of the system...
1. Volume 10 - Cut out after around 10 seconds.
2. Volume 20 - Cut out after around 4 seconds.
3. Volume 25-Max - Won't even do a single thump...Cuts out instantly at 25 Volume.
The Strange Solution: Which is really not a conventional thing that I can do every time I want my bass to come out from songs. After heating up the engine by redlining in 3rd and shifting into 4th (On 4 Spd AT...not going to say the speed that is cause I'm sure most people know) They can magically work at max volume until the engine is shut off and cools down.
The Permanent Solution: What I'm looking for...
My friend that works on cars and audio systems thinks it's a shorted fuse...but that doesn't explain how heating the engine magically allows them to be happy...so...any ideas on what it may be?
Old Feb 23, 2012 | 10:06 PM
wahkupup's Avatar
Check your battery and charging system.
Old Feb 23, 2012 | 10:11 PM
Rewire's Avatar
Sounds like a plan. Will do that tomorrow when I wake up. Thank you.
Old Feb 24, 2012 | 12:41 AM
WikkedOne's Avatar
Deals on wheels
a loose battery wire would do that.. it would get enough juice for lower volumes and wouldn't be able to provide enough juice for higher loads
A bad battery/alternator would do it too
Check all your connections then stop by Autozone and have them put the battery tester on it.
Old Feb 24, 2012 | 01:19 AM
Rewire's Avatar
I do know that one of the receptors on my battery is worn down to the point that it just slides right off...so that's probably the issue. I'll just take it to the dealership cause it's been like that ever since I got it (the receptor that is) so they should fix it under my bumper to bumper warranty.
Old Feb 29, 2012 | 06:44 PM
jzamarripa's Avatar
I have a similar problem. My driver side door speaker will go out and come back on when going over bumps. I think it's the mini Bose amplifier crapping out that connects directly for the speaker. Anyone have a similar situation?
Old Feb 29, 2012 | 07:15 PM
firebirdude's Avatar
User and Abuser
Relay. Check the FAQ.
Old Apr 17, 2012 | 09:13 PM
jcrewlee's Avatar
My driver side speaker works sometimes and sometimes it doesn't work. I found out that if i hit the speaker cover on the door, it will turn back on for a few seconds. Also the rear speaker on the left side (same as driver side) is somehow connected to the front speaker because if i turn the fade all the way to the front/left, the left rear speaker is still playing. Any solutions before i start tearing apart the dash? OH BTW its a 2004 Bose System.
Old Apr 17, 2012 | 09:58 PM
User and Abuser
I think maybe I'm going to stop posting here...
Old Apr 17, 2012 | 11:03 PM
StealthTL's Avatar
Metatron
You're not listening firedude!
He says "if i hit the speaker cover on the door, it will turn back on for a few seconds."
.....you know, where the relay is!
.....in the door!
What part of this are you missing????
Old Apr 17, 2012 | 11:05 PM
User and Abuser
I don't know. Maybe I should make a few new topics about it.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
RAVSPEC
Vendor Classifieds
Oct 1, 2015 01:59 PM
D13
Oct 1, 2015 07:55 AM
FubarI33t
Sep 28, 2015 08:45 PM
Learners_Permit
Sep 27, 2015 07:38 PM
