Drifting the RX8...issues?
Old Feb 12, 2012 | 08:21 PM
VashCloud's Avatar
Tuner Alliance CEO
So I took my car to a drift practice yesterday, ive drifted it before fine....but this time I had a little above a quarter tank. After I started to warm up doing figure 8's the car started losing power. Just like a fuel cut. Once second im sliding, the next the engine bogs down and no power. As soon as I lift off gas and try again I can slide until it happens again.
What would cause this issue? I went and got gas and filled her up but still had same issue. Is the stock fuel pump THAT weak?!?!?
Also I threw a oil light even though when I checked it i was topped off....
Car has brand new BHR ignition set and iridium plugs since Christmas. Is not tuned. N/A setup
Old Feb 12, 2012 | 10:08 PM
monchie's Avatar
I HATE SPEEDBUMPS!
It could be your fuel pump. Anyway, what is the mileage do you have in your car right now?
Old Feb 12, 2012 | 11:28 PM
WTBRotary!'s Avatar
Drummond Built
not enough fuel... fuel starvation... nothing wrong with your car...
Old Feb 13, 2012 | 12:00 AM
Arca_ex's Avatar
BECAUSE RACECAR
Yeah at 1/4 tank you get fuel starvation in left hand turns. It's normal.
Old Feb 13, 2012 | 12:05 AM
yep,
i would not even know how to drift a car, or why anyone would do it.. but i would not let the tank drop below 1/2 tank.. really..
btw, you will have the issue in left hand turns/drifts.
Old Feb 13, 2012 | 05:50 AM
VashCloud's Avatar
Tuner Alliance CEO
Ya like I said, I went and put in a fuel tank! And still had same issue. Someone said check your Oil pump.
My Rx-8 has 103k compression test @ 96k should excellent compression, I never have replaced fuel filter.... Had car since 42k miles. Purchased from another rx8 member, old dude too, he really took car of it.
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
nnsoch1776
Jul 22, 2015 04:16 PM
AussieGray
Jul 16, 2015 03:58 AM
Imp
NE RX-8 Forum
May 5, 2004 11:46 AM
RX7FD3
79
Nov 23, 2003 10:52 AM
