need help with altnator voltage
Old Feb 7, 2012 | 02:32 PM
hellbringer's Avatar
hello
i am using on my Rx8 an dc /ac inverter 12V to 220V AC and it has a protection
the protection is turning on when the input power is above 15V
after messure that i took i saw when i play with windows or light i got a pick to
15,10V+ <instant> and goes down to normal to 14,50V
I need something to low the pick under 15V
pls be specific if you say something about diods etc
thanks a lot
ps: the power that i messure is from the lighter
Old Feb 7, 2012 | 04:21 PM
firebirdude's Avatar
User and Abuser
English isn't your first language is it?
If I'm reading this correctly, you're seeing an instant spike in voltage to 15.1 volts when you put a load on the system (windows,etc), but then it instantly drops to 14.5 volts?
It really doesn't sound like anything is wrong. The alternator has a voltage regulator built onto it. When you increase the load on the alternator, it is forced to output more amperage. But the regulator is probably just trying to compensate for this instantaneous increase in load. It's a balancing act. A tiny split-second spike in voltage like that doesn't seem odd to me. The battery should help smooth out spikes/ripples in voltage. I guess it's a possibility your battery is a little old and maybe not doing this very well, but I really don't see a problem.
I'm not sure what you're trying to power with the 220V power inverter. Usually they're not good for anything more than charging a battery to a personal electronic device (laptop battery,etc). And they're usually useless for anything more than about 10amps. I'd try a different inverter. See if you still have problems.
Brettus
Series I Engine Tuning Forum
46
Apr 19, 2024 06:28 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
stickmantijuana
10
Oct 27, 2015 04:11 PM
gregs
Aug 6, 2015 11:43 PM
Majictoast
Jul 18, 2015 06:45 PM
