AT Brake pedal and MT Brake Pedal compatability
Ok i need to know if the MT brake pedal works direct bolt on with a AT setup without problems. Im aware the unit splits into two halves and the MT pedal will pug into the upper half of the AT's bracket, but i wanted to be sure the MT pedal will work on a AT setup. Thanks
I can't find the thread, but there is a serious one one on a full swap from automatic to manual, engine swap and all- it's been done in the "how to" section. It would take a lot of work just to have a smaller pedal. I thought about doing the complete swap, so this was on the parts list.
found it https://www.rx8club.com/showthread.p...highlight=swap
And ive already put the brake pedal in at this point... a little tricky but wasnt too hard. I found installing brake rotors more difficult
