Compression test results
Old Jan 21, 2012 | 12:07 PM
icarusaxu's Avatar
CA Compression test results
Hey guys
So looking to purchase a RX8, I found a 2004 with 67k
Thanks to this forum, I noticed the hard starts were taking about 4 seconds, so told the owner I wanted a compression test done
The results were ~
6.2, 6.4, 6.7, 9.2, 9.3, 8.9
Cant remember the second line
I've looked through the sticky graph but I"m not too sure what RPM they tested at, maybe someone will know. Are these results okay? They numbers seem to be quite apart?
Anyway the dealer said the compression was fine, and told the owner he must get new coils and a new starter ASAP ($1k)
Opinions?
Old Jan 21, 2012 | 12:12 PM
bse50's Avatar
#50
At what rpms was the test performed?
It looks out of spec anyway.
Old Jan 21, 2012 | 01:43 PM
xexok's Avatar
How can those numbers be called fine? The 9's on the second rotor look good but if they were both ran at the same rpm and have that much of a difference between the 2 rotors I thought that was a fail.
Old Jan 24, 2012 | 03:17 PM
Supernaut6's Avatar
Yea that's just terrible. I'm almost 100% sure that the test was done above 250rpm as well. You got this test done at a Mazda dealership? Which one?
Old Jan 24, 2012 | 03:54 PM
ShinkaEvo's Avatar
Triangular Bee Hive
Why new starter...O_o;
Old Jan 24, 2012 | 04:08 PM
pistonhater's Avatar
I thought out of spec was below 6.0
Old Jan 24, 2012 | 04:59 PM
itachi1's Avatar
Hi guys, I just got my 2004 RX8 a few weeks ago, I still haven't done a compression test? still to do. But I'm going to ask since it's been mension hear "why change the starter??" my starter is also weak sometimes it takes 3 seconds to turn on and sometimes it just doesnt start and it will start until the second try. So do I need to change the starter or will a new one be the same way??? sorry haven't read all the rules yet so don't jump on me... :-)
Old Jan 24, 2012 | 05:08 PM
zoom44's Avatar
that much difference between one rotor and the other is unacceptable. its either a bad test or a bad rotor
Old Jan 25, 2012 | 09:49 AM
icarusaxu's Avatar
CA
Sorry just to clarify, the test produced six results which were layed out on the sheet of paper like this
so the higher numbers were a testing at a higher RPM.
I got the test done at Neftin Mazda Thousand Oaks, not too sure they knew what they were doing, especially after they all marvled at the immediate cold start but didnt seem too concerned when I raised issues about the long warm start.
By the way Itachi, if your going to put a new starter in definately do it yourself! Or if your in California I found a rotary place which will put it in for half the price of the dealership
Old Jan 25, 2012 | 11:57 AM
Supernaut6's Avatar
so the results were
6......., 6....... @ RPM A
9......., 9....... @ RPM A + X
Is that correct?
Without the RPM, the tests results are meangingless. I would go back and complain and make them test the car again for free.
Old Jan 29, 2012 | 02:54 PM
04RX8man's Avatar
Rotary Powered Countryboy
There is a factory spec with variance between rotors( a certain percentage) that is 33.3% roughly difference which is way too much....like said before bad test or bad engine.
Old Jan 30, 2012 | 11:46 AM
xexok's Avatar
Originally Posted by Supernaut6
so the results were
Is that correct?
Also he mentioned the car being started cold there, that can have an effect on numbers if the test was done then.
I would go complain as well, and make sure you arrive with on time with your car hot. Don't let them wait and let it sit for an hour or more tell them it needs to be done when its hot. You will have better compression when the engine is colder.
Old Jan 30, 2012 | 12:08 PM
Supernaut6's Avatar
I believe he said we were reading the results wrong and the differences are very tight.
Truuuuue I forgot about that.
gwailo
May 14, 2024 06:57 AM
WranglerFan
Aug 21, 2022 01:29 PM
TJSiegrist
Sep 10, 2015 09:29 AM
rxwilly8
Sep 2, 2015 02:42 PM
