Power Loss, V-tec sound when acceleratin above 6k. In much need of help.
Old Jan 15, 2012 | 07:28 PM
iPodJohn's Avatar
Exclamation Power Loss, V-tec sound when acceleratin above 6k. In much need of help.
So now i got a problem with my 8..
Got terrible growling, kinda v-tec sound and slight power loss when accelerating after the car has warmed up properly. sound comes at around 6k rpm and stays on til its close to redline. It happens when i drive with out accelerating, just normal in town cruise.. keeping car under 4k revs. And when i rev it to the redline the sound comes up at around 6ishk to 7ishk rpm. But it seems if i rev up to redline in neutral right before flooring it in gear, clears up the problem and i can accelerate with out any problem for some time then it comes up again.. Feels like somthing is clogged and needs to be cleared up before i accelerate properly.
Here is a video with a similar problem that some one has, listen well when he accelerates.. This is not my car in the video.. Just same problem as i have.
Also the car has really hard time starting when its fully warmed up.. needs to sit around 10-15min before i can start it up.
Then info on my car.
77k km, around 45k miles.
Newly replaced - coils, plugs (may be flooded), wires, aftermarket cat, front and rear oxygen sensors, new battery.
The car has never been decarbed.
using 95 unleaded fuel
i redline nearly every day.
its 6 gear mt.
Any info would be great! And if u need more info just ask and i will try to provide as much info as possible
Old Jan 15, 2012 | 07:56 PM
paimon.soror's Avatar
what aftermarket cat...
Old Jan 16, 2012 | 02:06 AM
iPodJohn's Avatar
sopose to be same as OEM.. But it happened before i changed the cat..
Old Jan 16, 2012 | 04:58 AM
REV-N-HIGH's Avatar
I got a similar sound after I changed my cat, its a high pitch (almost like an airplane!) I hear it only on cold starts and when I go into 6th gear, getting checked out tomorrow.
I installed a Racing Beat cat..
Old Jan 16, 2012 | 07:21 AM
iPodJohn's Avatar
^ As i said in comment before, it came before i changed the cat.. And the sound is more like growling, air sucking go-cart noise from under the hood. Not high pitched
Old Jan 16, 2012 | 12:42 PM
zoom44's Avatar
didnt hear a thing on that video and its not your car anyway so...
where do you live?
MikeTyson8MyKids
Nov 12, 2022 11:54 AM
ladnarf1
Apr 29, 2021 11:53 PM
Dokuji
Nov 1, 2016 02:51 PM
uZu
Dec 30, 2015 12:35 PM
Kanthinar
Dec 21, 2015 01:24 PM
