RX8 Tractor!
Old Jan 14, 2012 | 06:22 PM
maxxed's Avatar
Red face RX8 Tractor!
Greetings! Long time reader, first time posting
I have a bone stock 04 RX-8 that is running like a tractor.
It sounds like only one of the two rotors is firing.
I decarbed and replaced the plugs and wires about a month ago and shes been running great, but this just started today. She died at a red light, I fired it back up only to hear what sounded like one rotor firing.
I pulled the codes and its tossing a p0302 (cyl 2 miss fire). I defiantly know one of the rotors is not "running" (prob a bad coil or maybe bad injector?)
I'm hoping its just a dead coil. But before I get my hands dirty, I'm curious which rotor is #2?
With the driver side front wheel off, looking at the plugs, is it the right rotor or the left?
I'm probably going to start with poking a screwdriver in the plug wire socket and see if I'm getting fire, but I would like to start on the funky rotor first
I may be mistaken here, but from what I understand, only one of the two (leading and trailing) plugs fires at start and idle. Is this accurate? If so which one is suppose to fire, the leading or the trailing? Do both plugs ever fire, or do they alternate at higher RPM, or something else? I'm pretty much a rotary noob so please bare with me
Old Jan 14, 2012 | 06:32 PM
Jake33's Avatar
Dudemanbro
take a video of it i just wanna see what it sounds like
Old Jan 15, 2012 | 09:09 PM
dirkyd3rk's Avatar
Rotary Noob
Try searching for "marbles in a can" maybe your engine is going bad...
Old Jan 16, 2012 | 10:53 PM
monchie's Avatar
I HATE SPEEDBUMPS!
Tractor sound means there is really something wrong with it. Have it checked out as soon as possible.
Old Mar 10, 2012 | 01:24 PM
maxxed's Avatar
Red face apex shitpex
So I've finally got off my lazy *** to check things out further!
It looks like the rear rotor is not "running" so to speak, I pulled the plugs out and they were wet (fuel). I hope I can luck out and it just a bad coil or something, but the real concerning find was tiny fragments of metal on/in the plug.....fsck!!!!!!! I'm betting money one or more apex seals have failed, if not completely they have at least cracked or broken into bits and blasted out the exhaust.
When the boss lady gets home, I'm going to have her turn the car over while I check to see if I'm getting fire.
What I need to know here is the firing order on cracking and idle, do both plugs fire at the same time, or does it alternate between leading and trailing, etc?
Let me know and wish me luck, lol
Old Mar 10, 2012 | 01:36 PM
maxxed's Avatar
Not sure if this is correct, but from what I've found it is on idle is
Rotor 1 Trailing, then Rotor 1 Leading, then Rotor 2 Trailing, and then Rotor 2 Leading.
Above idle, it flips
Rotor 1 Leading, then Rotor 1 Trailing, then Rotor 2 Leading, and then Rotor 2 Trailing.
On cranking, is the order the same as idle? Or is it something completely different?
Old Mar 10, 2012 | 02:06 PM
wcs's Avatar
wcs
no agenda
On cranking only the lead coils fire
Old Mar 10, 2012 | 02:37 PM
maxxed's Avatar
Excellent, thanks!
Am I correct with the order when at idle and then above idle?
Old Mar 26, 2012 | 10:23 AM
maxxed's Avatar
damn, my worst fear, the motor is shot. apex seals on the #2 rotor are blown
looks like i get to do a motor swap sometime soon. looks pretty easy to pull it from the rear though, so im going to go that route.
wish me luck!
Old Jul 17, 2013 | 09:23 AM
RXperimentsz's Avatar
Hey I have the same thing going on. My 8 is making that tractor noise too. Engine just got replaced at 135000 and now the cars at 157000 the reman engine only has 22k kms on it. and the spark plugs were changed with the reman engine. I started feeling powerloss above 7 rpm and then all of a sudden it stalled as I pulled up on my friends driveway. I tried starting it. It wouldn't start. I waited 5 mins and started it again. This time it took atleast 7-8 secs of cranking for it to start but it started making that tractor noise. It drove fine, till Iwas pulling into my street. The noise got louder with higer revs and started making a louder noise each time I let the revs come down. I checked the cels I got p0302 rear rotor misfire and p0171 system running too lean bank 1 and the p2076 (noticed cat was glowing so I gutted it out) so its not the MIAC sound. So p2076 is gonna stay I'm okay with that. I changed my coils yesterday and the noise went down a lot but its still making the tractor sound. So I checked the codes again and now the misfire and lean are both pending codes. I played around with my ssv and that's moving easily. The noise is there in idle and under load. Need help pls.!
Old Jul 18, 2013 | 01:18 PM
maxxed's Avatar
Turns out it was an apex seal failure. Need to replace the engine. I determined this by performing a compression test on both rotors. Still have not replaced the engine, debating on selling the car as is, maybe somebody else will want to deal with it :/
05TR1CH
Apr 18, 2023 04:56 AM
Skyl3r
Dec 2, 2019 04:51 PM
SupraG
Sep 21, 2015 12:09 AM
vetteor8
Jul 25, 2015 11:43 AM
RX7.9
Jul 20, 2015 12:01 PM
