Engine burning off oil too quickly?
Old Jan 13, 2012 | 04:01 PM
ZeroKunoichi's Avatar
I have had to fill my engine with engine oil near 1500-2000miles is that normal for the renesis?
I fill my oil up to the top line of the dipstick when I do my oil change and/or filter change.
If you guys need me to provide more information please tell me I'd be glad to share.
Thanks in advance everyone
Old Jan 13, 2012 | 04:23 PM
FastFreddy61's Avatar
When you say you had to fill your engine, how low was the level and how much did you add ?If you have an owners manual, have a read, it will give you a rough idea of how much oil the engine consumes.
Old Jan 13, 2012 | 05:00 PM
ShinkaEvo's Avatar
Triangular Bee Hive
Never had to add oil in my 7 years of ownership, and i rev to redline whenever I hit highway.
However, some of my friends' 8 do burn out oil and some don't.
Just saying...
Old Jan 13, 2012 | 05:06 PM
The 13B MSP is designed to burn oil.
Old Jan 13, 2012 | 05:27 PM
ShinkaEvo's Avatar
Triangular Bee Hive
I think we all know that, but my question would be more toward what makes the differences in the amount of oil it consumes.....compression? Just guessing.
Old Jan 13, 2012 | 05:49 PM
dizenman's Avatar
According to mazda, the renisis can burn 1 quart of oil in 600 miles. This is word for word what they told me and the exact reason they would not honor the warranty on my engine despite having the oil changed 2300 miles earlier (and topped off 2 days earlier, but they ignored that fact).
Old Jan 13, 2012 | 06:18 PM
The level was to where the sensors in the dashboard would light up. This is below the dipstick level.
Also, what is 13B MSP?
@Shinka: I am running everything stock I rarely redline my car either although I have read online my car was designed to be "reckless" with it.
Thanks again everyone for helping me
Old Jan 13, 2012 | 06:47 PM
Zero, the 13B MSP is the classification for the engine in the RX8. The oil consumption you have is normal, but, instead of waiting for the light to come on, check the oil at each gas fill up.It would be advisable to redline it at least once every time you drive it.This is to prevent excessive carbon buildup.
Old Jan 13, 2012 | 07:45 PM
ShinkaEvo's Avatar
Triangular Bee Hive
Op, since you rarely redline it, despite how much carbon buildup could be, that means ur are running at lower rpm (average) with less oil consumption...
I've seen 8 with oil all over the oil pan area...might wanna check it just in case.
Old Jan 13, 2012 | 08:13 PM
Jake33's Avatar
Dudemanbro
^your answer right there man
Old Jan 14, 2012 | 10:39 AM
Thanks for all the insight everyone.
@Shinka: I will check the oil pan and see about all the oil stuff.
I will start driving the car how it was meant to be driven.
@Freddy: I will check the oil on every fill up.
Another question, is it harmful to mix synthetic oil with non-synthetic oil together as a fill up?
I did a search on the forum about the weight of the oil not to matter when you mix them but I did not find anything about mixtures of non-synthetic with synthetic oil.
Old Jan 14, 2012 | 12:25 PM
wcs's Avatar
wcs
no agenda
What?!??!
You let your oil go that low ... ouch not kewl.
Old Jan 14, 2012 | 12:37 PM
wcs's Avatar
wcs
no agenda
Don't think compression effects the oil consumption in anyway shape or form.
The oil is injected and the amount is controlled by the oil metering pump which gets its commands from ecu.
With the ATR we have access to two tables that will allow adjustments to the amount of oil delivered by the OMP.
Load Based
Throttle Based
Old Jan 15, 2012 | 02:48 AM
Zero, concerning the mixing of Dino ans Synth, some ppl so yes and some say no, but considering when we do an oil change, there is still a few liters remaining in the oil cooler's and line's, IMO it won't be a problem.
Old Jan 15, 2012 | 06:46 AM
Load Based
Attachment 180466
Throttle Based
Attachment 180465
So, if I see this correctly it takes about double the amount of oil at higher RPM's but who is really going to drive their car at such High RPM's constantly at long period of time?
Actually, what is the calculated load?
@Freddy: Okay, thanks again then I think that answers a lot of my questions already.
mr. GrandGame
Sep 9, 2025 10:41 PM
vapor2
Nov 3, 2020 03:38 PM
robd1337
Jul 31, 2015 09:35 PM
Davey's RX-8
Jul 28, 2015 12:13 PM
vssystemluba
Jul 19, 2015 04:16 PM
