Help!
Old Jan 6, 2012 | 01:11 PM
RX Z88M's Avatar
Talking Help!
Alright guys need advice...
Wheel
Front:18x9.5 Offset+22
Rear:18x10.5 Offset +22
Tires
Front:225/35/18
Rear: 255/35/18
Suspension
Tanabe gf210
Don't bash to hard...I'm a chick that just wants a dope
ride.
Old Jan 6, 2012 | 01:19 PM
Atilla's Avatar
I am THAT guy
quick reply -
this question belongs in the "Aggressive fitment thread"
btw -
you're gonna need a fender roll and a pull - shave the bumper tabs as well w/some camber work.
If you're gonna dump the ride for a hellaflush look - you might wanna consider a more aggresive front setup. The fronts are gonna be sunk. The rears will look a bit better n' possible w/slightly wider tires n' a gracious fender pull it'll look good.
good luck - hope this helped
Old Jan 6, 2012 | 03:28 PM
mavictb's Avatar
ask around in the agressive wheel thread like atilla said. something to consider is that even though both of those wheels have the same offset the 10.5 is more agressive and will stick out further. on the 9.5 a 225 tire will be pretty stretched when its not really needed... unless you look at a 18x9.5 +15 a wider tire would be better for the front. the rear will need roll/pull cut bumper tabs and camber like mentioned.
my suggestion would be run a square 9.5 with 245s with +15 - +22 offset depending on how much camber you want to run and how much you want to rape your fenders. if you wanna go big the 10.5 +22 would be nice on front and rear with some 255s.
