help
Old Jan 6, 2012 | 01:15 AM
shage r8's Avatar
help
Hi 2004 rx8 automatic transmission has 103k miles on it and recently a very high vibration is occuring after egnition and gets even higher once i shift to D drive or R reverse also at ideling or at low speed when rpm is 1200 to 2200 the dealer check and autofax declared that driver side engine mount is busted so am going to change it soon
but at the garage when i lefted the car on the jak i noticed that the drive train is vegiorisly shacking my mechanic said it might be a driveshaft or drive train problem that requires balance or even change!
if anyone had this problem and solved please let me know what the solution is
thanks
Old Jan 6, 2012 | 01:57 AM
Wingznut's Avatar
Go Red Wings!
Here's a tip for you...
If you want people to take time out of their day to help you with your problems, then you should at least take the time to write cohesive sentences with punctuation. The people here love to help, but nobody wants to have to decipher your sloppy message first.
