Car slow to turn over after starting and the stop and go
Old Dec 28, 2011 | 08:01 PM
dkzoom's Avatar
Looking for some help - new to the club and I wish I had joined long ago - I have a 2005 rx8 and just spent $1,000 on new engine coils, spark plugs and a crank sensor (which were the main items) and now when I first start the car it turns over ok but then if I stop for an errand and back to start the car it's very slow to start up again. If its the starter why didn't the mechanic tell me that last week when the car was there? I have 95,000 miles on the car and out of warranty. Questioning what I should do. Thanks for your help!
Old Dec 28, 2011 | 08:09 PM
RX8Soldier's Avatar
Time for boost...
any mods?
Why do you say you are outside of warranty?
Try this thread https://www.rx8club.com/showthread.php?p=4071081
Old Dec 28, 2011 | 09:41 PM
dkzoom's Avatar
Thx for the thread - what are mods??? I will call Mazda to see about the starter upgrade and if eligible
Old Dec 28, 2011 | 09:42 PM
FastFreddy61's Avatar
mods= modifications
Is the starter slow to turn the engine over, or does the engine turn over quickly but doesn't fire as quickly as when cold ?
Old Dec 28, 2011 | 09:48 PM
RshnRoket's Avatar
Rotards Unite!
Get a compression check asap. I had the same problems over the last two weeks, and thought it was the same problem you were describing. My compression check failed...
Old Dec 29, 2011 | 09:38 PM
dkzoom's Avatar
Everyone is so helpful so thank you! The car is slow to turn over but once it does it fires up fine. A compression check? If it fails what does that mean in terms of repairs? Expensive? Appreciate any help as I try to avoid the dealers since thh are so expensive and prefer the local mechanic as long as I am educated about be problem.
Old Dec 29, 2011 | 10:01 PM
Zoom, as Roket suggested, get a compression test done, also, how old is the battery ,I would have that checked at an auto electrician,the early series of 8's had a weak starter, not sure if yours falls into that category ,search the forum for more info on starters. If the motor has failed and needs replacing, your looking at around 4k-10k , depending who does it and what is done,but seeing as yours is an '05, your motor should still be under warranty .
Old Dec 29, 2011 | 10:21 PM
dkzoom's Avatar
Thanks again I will look into a compression test then. The battery was replaced last year so bar should be good. The car is not under nor covered by warranty - I didn't opt for the extended coverage. So pending the outcome for $4k it could sadly be bye bye to the zoom zoom stupid question. It where do I find an auto electrician??? Aren't car mechanics savy with this or no?
Old Dec 29, 2011 | 10:30 PM
Some mechanics are able to do the test of the battery,some are just monkey's in uniform. You can do it yourself if you have a multi meter, if your in the US, I would contact Mazda North America, give them your VIN, they will tell you if it's still under warranty.Im sure its 8 years from date of sale, or 100k miles.
Old Dec 30, 2011 | 12:47 PM
RX8Soldier's Avatar
Time for boost...
here is an intro thread you should read. I don't know if all of the warranty info is in here, but it's a place to start
https://www.rx8club.com/new-member-forum-197/new-potential-owners-start-here-202454/
Jesus Martinez
44
May 6, 2025 08:09 AM
Quato_jr
Aug 4, 2015 09:22 AM
digitalmonkey79
Jul 29, 2015 12:09 AM
T_Mags
Jul 24, 2015 11:29 AM
ironj221
Jul 16, 2015 10:16 PM
