Boost Solutions/TurboRX8.com turbo kits in the works
Old Mar 8, 2004 | 12:45 PM
Boost Solutions's Avatar
Check this out
https://www.rx8club.com/showthread.p...hreadid=22653;)
George
www.turborx8.com
Old Mar 8, 2004 | 01:31 PM
wakeech's Avatar
mostly harmless
...could you please tell me why you're going so unbelievably overkill for a measly 7 - 10 psi?? that turbo seems a might bit big, along with most of the other stuff...
Old Mar 8, 2004 | 01:49 PM
If people are interested in smaller setup, we will offer that as well. But a good effiecient turbo will make 350whp at 10 psi no problem. On the intercooler, we do not want any detonation issues, so the bigger intercooler will take of that.
George
Old Mar 8, 2004 | 02:00 PM
wakeech's Avatar
mostly harmless
...right. the thing is that the T04R isn't very efficient at such a low flow rate (that turbo hits its stride well into the mid-to-high teens, up to the low 20's... i know), not to mention i'm sure you're doing this for the 6 port motor (which doesn't have the better flow characteristics of the 4 port), and this turbo has a 0.96 (completely overkill for those power levels, and underspoolin' for around town) A/R ratio.
and also, why are you sourcing an HKS turbo when it's just another Garrett clone?? can you get them cheaper than other American makes (like T'netics and whoever else)??
Old Mar 8, 2004 | 02:03 PM
The pictures are with the HKS, the turbo will be Garrett
George
Old Mar 8, 2004 | 03:20 PM
rotarygod's Avatar
Originally posted by wakeech
[Bnot to mention i'm sure you're doing this for the 6 port motor (which doesn't have the better flow characteristics of the 4 port), [/B]
That was true up until the Renesis. The new 4 port engine is not even close to the intake port timing or intake runner area of the last 4 port engines. The 6 port Renesis is the better choice for turbocharging while the 4 port 13B is a better choice.
Old Mar 8, 2004 | 03:23 PM
rotarygod's Avatar
For a moderate power increase up to but not over about 350 hp on the stock engine I would favor a T-04B instead. Size is nothing witout efficiency. Even a 60-1 HiFi could put out 425 rwhp at only 15 psi and it is much smaller than the T-04R. Efficiency is everything.
Old Mar 8, 2004 | 04:12 PM
We will be trying out several turbos
Some people have asked us for big turbos, that will allow them to run 20 psi. Some other people want to stay under 10 psi.
So we are still deciding on the turbo setups.
George
www.boost-solutions.com
Old Mar 9, 2004 | 04:39 PM
JSE RX-8's Avatar
When do you think the project will be finished and we will see some dyno numbers. i am also interested to see the price for the kit and price of installation
Old Mar 9, 2004 | 04:55 PM
I am getting my built Evo engine this week, so the RX8 is going for the manifold next week. Give us at most a month.
The price estimate should be done after we settle on a turbo.
George
Old Mar 9, 2004 | 11:28 PM
Boost Solutions/Turborx8.com Turbo kit specs
Hi everybody,
since you guys asked for more specs on the turbo kits, here they are:
Turbo kit #1:
- Garrett T04R turbo, with .96 AR housing and P trim wheel ( better spoolup), 4"mm inlet pipe, 2.5" compressor outlet pipe, 3.5" downpipe, GT series comp wheel for excellent efficiency on low boost
- Tial 40m silver wastegate, plumbed back to the downpipe
- Stainless steel 3.5" downpipe
- equal length SS exhaust manifold
- Blitz intake filter
- hardware and oil lines
Turbo kit #2:
- HKS T04Z ball bearing turbo, with .61 AR housing , 4"mm inlet pipe, 2.5" compressor outlet pipe, 3.5" downpipe
- HKS Racing SS wastegate, plumbed back to the downpipe
- HKS 200mm intake filter
Intercooler kit#1:
- Spearco (or PWR) intercooler , 24"x8"x3.5"
- all polished aluminum piping, with choice of red, blue, black connectors
- blowoff valve flange ( customers choice)
- HKS SSQV, Greddy Type S, or Blitz Super Sound blowoff valve included
Intercooler kit#2:
- HKS intercooler , 600x244x65mm, Type S core with polished endtanks
- all polished aluminum piping, with blue HKS connectors
- HKS aluminum BOV flange
- HKS SSQV blowoff valve
ECU
- Ric Shaw Performance piggyback ECU controller
Fuel system
- upgraded secondary injectors
- upgraded fuel pump ( Walbro)
Here are some pictures:
- The HKS T04Z ball-bearing turbo
- the HKS intercooler ( piping will be diferent)
- the Garrett T04R turbo
Old Mar 9, 2004 | 11:30 PM
wolfbeast's Avatar
prices?
Old Mar 9, 2004 | 11:37 PM
Originally posted by wolfbeast
prices?
It all depends on the manifold, that is the key in the whole buildup
We do not want to throw a number now, and then change it because the manifold was a lot more expensive.
Old Mar 9, 2004 | 11:38 PM
Mistryl's Avatar
will it work for automatics?
Old Mar 9, 2004 | 11:43 PM
We are testing it on a 6 speed first. After it is tested there, we will try it on an auto. But the ARs on the turbos will be smaller:-)
Old Mar 10, 2004 | 12:41 AM
Mistryl's Avatar
i'll take what i can get
Old Mar 10, 2004 | 01:14 AM
Psychofox's Avatar
我愛台妹,台妹愛我
when will it be out?
Old Mar 10, 2004 | 08:40 AM
XeRo's Avatar
Normality is Obscene
dude...are you guys near Suwanee? i have to go up there this week and would love to drop by...
Mxttz0r
Jul 5, 2019 03:19 AM
jay_tibo
22
Sep 13, 2016 08:10 PM
Modified Dave
Sep 19, 2015 08:58 PM
Sifu
Aug 30, 2015 10:51 PM
k4thomas
Aug 5, 2015 03:03 AM
