Need Help with HID Fogs and Fog Rewire
Old Dec 14, 2011 | 02:26 PM
Globetrahter's Avatar
Ok, so I did this mod tonight, I did mess up and it probably took way longer than it should. But After I cut the brown wire, I taped off the wire closest to the relay and then started using the other half of the brown wire to the (first) the black/red wire and my fogs would not turn on. 2nd I used the wire and connected it to the white/red wire and still no fog lights.
I then untaped the brown wire closest to the relay. Since I made a mistake and made the wire to short, I had to come up with a different way to make it work, so I cut the ACC relay (thin white/red wire and connected it to my brown wire and voila it worked, now my fogs turn on independely of the headlights and the parking lights which is awesome.
OK Now! I also was installing my HID Fogs from VVME. I got all the way to hooking up the Ballast and they are the 35w Kit. When I turn on my Fogs I hear a sound like its getting power but no lights come on. I plug back in my original fog light bulbs and they work fine. Could this be because I have the Fog Wire connected to the ACC relay and its too much power? If so How can I fix that?
Let me know if I need to explain it better cause I know it seems alot and Im probably not using correct terminology with all this.
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
wayloco
Sep 1, 2015 09:03 PM
