Start issues and car dying after start
Old Dec 13, 2011 | 03:44 PM
dirtystyle's Avatar
Hope someone can help.
Specs: 2005 RX8, ~55K miles but the engine has maybe 1/2 that (was replaced; twice)
I've had the occasional hard start but nothing like this. Yesterday I had to move my car and it maybe ran for a total of 10 seconds. I get up to go to work this morning and the car wont crank over. It'll seem to crank endlessly and "almost" kick over sometimes but it never does.
I replaced the battery with an optima RedTop (wanted to do this anyway) and the problem persisted. The cranking did seem more even and consistent thanks to the new battery.
I then tried the deflooding procedure which after multiple attempts (like 7 or 8), got it cranked over and working (sort of).
After it started, a crap ton of white smoke was coming out of the back. I let it run for a good 15 min to let the smoke clear before I took it around the block a few times.
The drive around the block was a bit nerve racking. If I went from 6K to idle (totally warm engine), the car would die. It did start back up with only minor complains. Engine lights were coming on quite a bit.
I wasnt having any big issues except for a hard start here and there before today.
Any ideas? Should i keep it running longer and see if it clears out?
Old Dec 13, 2011 | 03:54 PM
RX8Soldier's Avatar
Time for boost...
Why was the engine replaces twice? Is there a scent to the smoke? When was the last time the car was serviced? Does the car have the original starter?
Old Dec 13, 2011 | 04:15 PM
dirtystyle's Avatar
1. Compression issues.
2. The exhaust smelled kind of normal, however there was a burning electric/clutch like smell coming from the front of the car. I dont smell that any more when I start up the car (ive restarted it several times without issues for the past few hours)
3. It's been well over a year
4. I'm not 100% sure but I think so.
SUKIEE
Oct 9, 2017 09:41 PM
Wantingtoknow
Dec 15, 2016 02:25 PM
marc2820
Jul 26, 2015 10:47 PM
harithac
Jul 25, 2015 04:21 PM
T_Mags
Jul 24, 2015 11:29 AM
