CHRIS RX8
12-08-2011, 10:19 PM
Im selling my 2005 Rx8. I have a million upgrade and parts into this car. It took me several months to built the car. The chasis has 46,000 miles and the new engine just has 9.500 miles. I have a 1999 big block 13b with cosmo intake. It has a custom made single turbo (Garret from Mike Turbo) T67 with a .96. The engine is street ported fully rebuilt from scratch, every single part put into the car was brand new. There are not many of these cars with this swap in the world. I think this is one of the few that has AC and everything. It drives and sounds amazing. The complete set up is just perfect.
Performance:
The car made 519hp on 93 pump gas. It is set up and tuned at 473hp @ 18 pounds, with 394 ift Lb (torque). Tuned by Alex Lopez Racing.
Engine: Complete Engine work and upgrades done by B&N Performance. Engine is a 13b cosmo intake, fully rebuild (all new parts into engine), street ported, reinforced, pinned. Custom engine mounts and brackets. Custom made header. Complete performance transformation and maintenance done by B&N performance.
Turbo: By Mike Turbo custom made. T4 Garret with custom blade. T67 with .96.
Computers: Micro Tech LT10s and X4 1GBT
BMPC Intercooler, new radiator
ALS Apex seals,
Two Bosch1200cc and two 1600cc injectors.
OS Giken Racing Multi-Plate Clutch
5 speed big block transmission imported from Japan
Ralco RZ Pulley kit (crank, alt, water pump, p/s)
Tial BOV 50mm
EMUSA Waste Gate
KB Parts Fuel Rail, primary and secondary rails
OBX Fuel Regulator
Bosch External Fuel Pump
Greedy Oil catch can
Racing Beat Coolant catch can and Reservoir tank.
Tanabe Exhaust with custom down pipe
MSD Spark Plug wires
Bosch Ignition Coils
NGK spark plugs
Evans Npg Coolant, Royal Purple Racing Oil.
Inside:
Black and Gray Interior
Cloth seats original
LED Complete Interior Lights (white)
Race Pak UDX Dash Board (RPM, Fuel %, Oil pressure, water temp, Speedometer, Odometer, signal lights, warning lights, and much more)
AEM WIDEBAND 52mm
AEM TRU BOOST 52mm
Carbon Fiber custom gauge pod
Sound System: JVC Multimedia Head Unit Navigation, Metra RX8 Dash kit, JVC Bluetooth ready, JVC IPOD ready, Power Acoustic 4 channel amp, Audiobahn 1 channel amp, Alpine 5x7 components, Pioneer 6x9 3 way speakers, 2 Kicker subs 10”.
Exterior:
Color: Sunny light silver
2 new head lights
Hid KIT low beam (8000k)
Hid Kit high beam (8000k)
Hid kit fog lights (8000k)
Original rims
Tires: Nitto NT 555 Drag Radials 245/45/18 100w (rear) Potenza RE760 Sport 225/45/18 91w (front)
Suspension: Tein Lowering Springs S tech (Drop: F: -1.40" / R: -.70")
Brakes: Hawk HP+ Ceramic Front and Rear Brake Pads. Break Calipers painted red.
Security: Clifford G5 Alarm, 3 sensors, Code Entry
$19,500 OBO
Performance:
ALS Apex seals,
Tial BOV 50mm
EMUSA Waste Gate
OBX Fuel Regulator
NGK spark plugs
Inside:
AEM WIDEBAND 52mm
AEM TRU BOOST 52mm
Exterior:
2 new head lights
Original rims
$19,500 OBO
