New guy from Maryland
Old Dec 8, 2011 | 06:42 PM
vader's fury's Avatar
Hello all,
Well I am going tomorrow to look at and possibly purchase my first 8. Found this forum and figured I would join up.
Hoping to find alot of info on here that I can use for the car as I am a guy that can not leave anything stock for very long. I have been modding Diesel trucks for the last 6 years and messed with honda's before that.
Been doing some searching and reading and sounds like I have alot to learn as the Rotary engine is WAY different then the piston engines I am used to.
Old Dec 8, 2011 | 11:11 PM
RobGraz's Avatar
Shinka
While it is WAY different. The general priorities are still the same, and if you're mechanically inclined and literate, you'll pick up on this engine very fast, especially if you read at least a post a day here.
Read up in the major horse power upgrades section, a lot of good diagrams and information to be had there.
Goodluck, get a compression test on that '04
Old Dec 8, 2011 | 11:16 PM
Jake33's Avatar
Dudemanbro
i went from a honda to an 8 too...welcome!
Old Dec 9, 2011 | 02:36 PM
Well no go on the 8 today. Car ran great but had a few things cosmetically wrong with it that the guy forgot to mention and the heat didn't work. Ended up passing on it but I did take it for a test drive and after ripping through the gears a few times I am hooked! Had not driven one before today but instantly was in love.
Def will have one of these in my driveway in the near future.....
Old Dec 9, 2011 | 02:53 PM
LifeAfterRx8's Avatar
Heat not working is actually a quick fix. Search the DIY Threads.
What year did you check out? An 04?
I would suggest paying a bit more and going with a newer 8.
An 04, depending on mileage is around 7-10k. You can get an 06-08 (lot less miles) for around 13-16k. That gives you more time on the 8y/100k mile warranty on the engine core.
Old Dec 10, 2011 | 05:29 AM
It was a 05. I am looking at an 08 on Monday. I had the same thought.
Old Dec 10, 2011 | 07:22 AM
rx2kill's Avatar
wanting another rotary
welcome bro
Old Dec 10, 2011 | 08:34 AM
Are-Ex-Eight's Avatar
Nice Rotors
Pics soon.
Old Dec 10, 2011 | 01:52 PM
Roidz's Avatar
Strength/Confidence
Good luck.
Old Dec 10, 2011 | 03:24 PM
monchie's Avatar
I HATE SPEEDBUMPS!
Post pics when you have it.
Old Dec 11, 2011 | 08:45 PM
Will do guys. Anything specific I should look at with the 08's
Old Dec 11, 2011 | 08:59 PM
sjschutz's Avatar
Big Poppa Steve
Just the basics. Don't have to be as picky as you would if you were looking at earlier models. Carfax, test drive, visual inspection, compression test. That should be a good start.
LB2739
Jul 9, 2019 02:25 AM
nowakm99
Oct 9, 2015 07:10 AM
Tsurugi
Sep 7, 2015 08:27 PM
