Won't Crank
Old Dec 7, 2011 | 10:40 AM
fiv3r's Avatar
Won't Crank
My rx8 has recently randomly not been starting. When this happens the starter will not crank or even click. I assumed the problem was a starter relay, and replaced that, but still no crank. Battery charge is good, so unless i'm missing something the problem would be the starter?
Old Dec 7, 2011 | 10:51 AM
Old Rotor's Avatar
What is the voltage at the battery? If you don't have one Harbor Freight add I saw one free...
Old Dec 7, 2011 | 10:58 AM
fiv3r's Avatar
Not at home to test it atm, but the first thing i did was put a charger on it, and it read full charge. I can put a voltage meter to it tonight after i get out of work.
Old Dec 7, 2011 | 11:00 AM
RIWWP's Avatar
When it simply doesnt start, do you have battery power to other stuff like lights, dash, etc?
What makes it then start later?
Old Dec 7, 2011 | 11:04 AM
Old Rotor's Avatar
If you have corrosion on your battery terminals or starter connection ...it could be your starter..
Old Dec 7, 2011 | 11:35 AM
lastphaseofthis's Avatar
Release the twins.
You should probably check the start solenoid clip first, if it's loose, it's likely intermittenly loosing contact, it could have come in contact with debris from the road.
Old Dec 7, 2011 | 11:40 AM
fiv3r's Avatar
Lights, dash, radio all work fine. As for when it would actually start, it was totally random, and i have not been able to start it in a week or so now.
Old Dec 7, 2011 | 11:41 AM
fiv3r's Avatar
No corrosion on starter, there was corrosion on battery terminals i cleaned off though.
Old Dec 7, 2011 | 11:52 AM
RIWWP's Avatar
So you have battery power, but the starter isnt turning over. It's going to be the starter itself or something that feeds power to the starter. Do you have a multimeter you can crawl under the car with and check for voltage between the starter connection and ground? If it's getting power with the key to start, then it's your starter. If not, then fuse, relay, etc...
Old Dec 7, 2011 | 12:01 PM
fiv3r's Avatar
I replaced the starter relay so i would assume its not the problem and the fuel pump runs when i turn the key to start, so i would assume its good as well.
I can borrow a multimeter from work and start checking voltages at the starter/solenoid and check to see if any connections are loose tonight.
Old Dec 7, 2011 | 12:26 PM
StealthTL's Avatar
Metatron
Is it an auto? Could be a neutral switch problem.
Easy way to check if the prob is in the actual solenoid and motor is to bypass the relay.
FIRST ensure if it's a manual it's out of gear!
Check the 30 amp 'ACC' fuse, this supplies starter solenoid power.
Ignition OFF, pull the starter relay from the fusebox, then use a wire jumper to join the two large contacts in the bottom of the relay holder - this bypasses the neutral swith, clutch switch, security block, everything.
The car will either turn over or not. (won't start)
If it turns over, it's a switch, if it clacks loudly but no spin it's the starter motor, if it's just eerily quiet, it's the starter solenoid.
Old Dec 7, 2011 | 03:03 PM
Old Rotor's Avatar
You did take them both off and clean the contact surfaces and retighten.....correct? Dusting off the top of the terminals does nothing. You might snap open the caps and check if distilled water is needed .....if it's near the top of plates.
Old Dec 5, 2012 | 03:46 PM
eche4183's Avatar
Wont Crank...
Im having the same issue, however when i bypass the solenoid the motor did not crank but can here the starter spinning.
Old Jun 18, 2015 | 05:18 PM
MANIACman's Avatar
Thumbs up
I know this is an old thread but had the same problem. Turn the key (Dash lit up fine) and nothing. No click - nothing. I tried a different key thinking it was the dumb security key jazz acting up. Nope! Wiggle the stick in neutral - nothing. Cursed, let my blood pressure go to insane levels and just steamed. Tried starting it probably a 6 or 7 times. Then I stood on the clutch. Really pressing it down and bam... It started.
I've only drive this car a couple hundred miles and this is the first time I had a problem. Of course I was in a rush to get to some government building before 4:30 *Who closes at 4:30 when your a public agency. SIGH... I didn't make it on time so I can drive around all day tomorrow... Wait thats a good thing! Zoom Zoom and aloha from Minnesota.
92trbolzr
May 18, 2025 09:04 AM
DylanForbes
25
Oct 31, 2017 05:47 PM
Luke.s
Sep 30, 2015 05:57 PM
p8ntman442
Sep 22, 2015 08:06 PM
Draken
Sep 21, 2015 06:14 PM
