Need some serious help with my 8!!!
Old Nov 29, 2011 | 10:34 PM
RoTaRyRx-8's Avatar
RoTorY
Ok so my 8 is in a bad concdition now!! and i need your help too helping me fix it i would appreciate it so much!!
Soo i think it all started when my sunvisor wires touched when i was taking it off! Now i have no light in the car,no light on the radio and it doesnt work at all now!! Fuses?
Also before that the car will not start with the key it will show everything but wont turn on with key and all the needles on the dash will go to the end fast and come back too normal?..i have too hold the clutch sensor thats by the clutch and turn the key so the car turns on...and also when i turn the key off theres a click sound in the engine.. starter maybe?
another thing is the car dies at idle only when it reaches temperature at cold its normal *** soon as it reaches hot it will die i have to hold the gas pedal too keep it alive! i used to mix gas before with regular gas and premium could it be the fuel pump? any help would help me fix the car *** it used too be
thanks for lookin hope anyone could help... and i did search but couldnt really find much
2004 mazda rx8 with 71K miless! mods are in the sig
Old Nov 29, 2011 | 10:53 PM
Easy_E1's Avatar
Arrgh. Well the one big thing that stands out is that it dies when hot. Compression?
Visor wires,, You blew a fuse. Find it and change it. Check the fuse locations as per your owners manual.
Clutch switch is not adjusted correctly or faulty. Adjust it/Replace it.
"Click sound",,, No idea.
Regular and Premium mix,,,, Why?
Old Nov 30, 2011 | 12:16 PM
RoTaRyRx-8's Avatar
RoTorY
thank you!! ill try them out
and yea only when i needed to refill my gas thats when i let my brother fill up gas so he used regular gas instead of premium!! ..and i went to auto parts to check for codes but that doesnt work either they cant scan it, theres something with the car
Old Nov 30, 2011 | 12:24 PM
RIWWP's Avatar
On the "click" point.... there is an audible "click" with every 8 that I've seen when you turn off the key. I'm not sure which solenoid/relay it is that is shutting, but it's there. Maybe this is what you are referring to?
Old Nov 30, 2011 | 12:29 PM
StealthTL's Avatar
Metatron
Check the fuses using a tester.
Eyeballin is no good, even taking each one out for a looksee can be a fail.
Old Nov 30, 2011 | 10:45 PM
RoTaRyRx-8's Avatar
RoTorY
thanks for the help ill try these out and get back too you!
Old Nov 30, 2011 | 10:47 PM
RoTaRyRx-8's Avatar
RoTorY
yeah might be that! i was thinking it could be the started since my car wouldnt start w/o me holding my clutch sensor thats by the clutch pedal!
Old Nov 30, 2011 | 11:03 PM
StealthTL's Avatar
Metatron
So you hold the 'clutch sensor' in, and the car starts, so you think it's the starter?
Patricia Odell
SE RX-8 Forum
12
Nov 14, 2016 02:40 AM
OfficerFarva
Dec 5, 2015 10:53 AM
WingleBeast
Sep 9, 2015 10:10 AM
