Metallic whirring/rubbing sound
Old Nov 28, 2011 | 10:16 AM
smokatoke's Avatar
Sound just started a few days ago, best I can describe is a metal object spinning and coming in contact and rubbing another object, very similar to the sound a circular saw makes when cutting wood. Only happens on cold starts and when I turn it off and on again, the sound is gone or goes away in a few seconds. I tried to isolate this morning, and when looking from the front of the car into the engine bay, it appears to be coming from the left side.
Any ideas?
Old Nov 28, 2011 | 10:35 AM
RIWWP's Avatar
If you let it idle to warm up, does the sound disappear after ~30 seconds?
If so, then I bet it's your air pump. The air pump injects air into the exhaust stream when the exhaust is still cold to accelerate the heating of the catalytic converter, as it isn't efficient until it's reached operating temperature. This is an emissions control device only, and doesn't run once the cat is hot.
The solenoid and/or the pump itself can both make strange noises.
Old Nov 28, 2011 | 10:41 AM
Easy_E1's Avatar
Your air pump is failing. I believe that it's covered by the EPA emissions warranty. Which is 8 years/80,000 miles. Check with your local dealer if your under that mileage.
Old Nov 28, 2011 | 11:32 AM
Wingznut's Avatar
Go Red Wings!
Yep, sounds like the air pump. Easiest way to be sure is to disconnect it when it's making the noise. (Or pull the air pump fuse.)
Old Nov 28, 2011 | 02:22 PM
smokatoke's Avatar
You guys are awesome, thx a million
Old Nov 28, 2011 | 02:41 PM
FastFreddy61's Avatar
Smoke, its actually on the right side of the car .
Old Nov 28, 2011 | 02:43 PM
RIWWP's Avatar
It depends on how you are looking at it. The perspective he said puts his left on the car's right
Old Nov 28, 2011 | 02:57 PM
Damn, I guess I should have read the whole post instead of skimming, please accept my humble opology .
92trbolzr
May 18, 2025 09:04 AM
theblinkof
Oct 4, 2023 05:24 PM
Digitz0070
55
Jul 25, 2017 08:40 PM
Evan Gray
Nov 24, 2015 01:00 AM
Racingjunkie
Sep 29, 2015 05:05 PM
