Seafoam and now I have P0335 and P0107 codes
Old Nov 18, 2011 | 08:13 PM
Mrktplayer's Avatar
Hi,
I have a 2006 with 27K miles. I've been premixing but had indications of too much carbon. I've been adding 8-10oz of premix per gallon. My exhaust was sounding louder and cold starts takes a bit longer. The symptons started showing up the past month. I did some research and decided to use seafoam, which I did today.
Now I have a CEL: P0335 and P0107 codes. The P0335 code seems like my cat is bad. Not sure what the P0107 is. I attempted to reset the ecu by removing the room fuse (for a few seconds) and the CEL is still there. I tried pumping my brakes 20 times and the CEL is still there.
After the seafoam the car is running a lot better but the codes have me concerned. Any help is appreciated, thanks
Old Nov 18, 2011 | 08:28 PM
ShinkaEvo's Avatar
Triangular Bee Hive
How's P0335 pointing to the cat...
How did you seafoam it....?
Old Nov 18, 2011 | 08:43 PM
Mrktplayer's Avatar
I did a quick search. It's an o2 sensor isn't it? I did seafoam via vacuum line. After a few starts and driving around some more the CEL is gone. I'm relieved because I'm going for a long drive tomorrow :-)
Old Nov 18, 2011 | 09:00 PM
lta_ds_fs7's Avatar
I hope you mean 8-10oz per tank...lol
Old Nov 18, 2011 | 09:43 PM
Junirol's Avatar
Toyota Master Technician
lol that could be your problem.. too much premix.
Old Nov 18, 2011 | 10:08 PM
:facepalm:
RX8Club is the epitomy of bad advice and intraweb mistruth parrots ...
Old Nov 19, 2011 | 12:31 PM
Mrktplayer's Avatar
lol, my fault. Yes, 8-10 oz per tank.
Old May 14, 2013 | 06:02 PM
MeDrinksBeer's Avatar
OR ap0355
I just recently got a po355 and ap0172 code which is eccentric cam position and bank one rich code. Looked on the shops computer and it said something about cam position sensor and maf sensor correlation so I pulled my intake and tested my maf and cleaned it. Then tested my coil output to see if they were causing the rich condition. They tested good but when I pulls the plugs they were super coated and one trailing plug had the gap fully closed just about. So I cleaned them put them back in and reset the codes test drove and neither has came back and it has been a couple days now.
Old May 14, 2013 | 06:40 PM
j9fd3s's Avatar
you should clean the Eccentric Shaft Position sensor (ESS, or crank sensor) they get dirty and then you should do the NVRAM reset.
92trbolzr
May 18, 2025 09:04 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
jamespond24
Dec 1, 2015 11:11 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
